Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
0 Members and 91 Guests are viewing this topic.
eisenficker2000
@AquiriuZ: Take picture 8 from the patent and bend back the ends near the axle, so the angle pushing the weight up has a smaller vector in the horizontal plane
@Cherryman: If you could use dxf/Autocad format?
Cherryman
Quote from: eisenficker2000 on April 12, 2009, 06:51:37 PM
Perfect! Send it up
Did you test it WM2D or something?
AquariuZ
Using Cherrymans wheel I can visualize the violent launch of the weights near 12 o clock position.
Now, if you can keep the weight in its socket you may have something.
There are small bursts of acceleration, but again the ball needs to be kept locked into place to get full benefit from the launch. The launch is a scissors effect.
Model attached with an initial momentum of -0.200 rad/s but WITHOUT MOTOR.
Turns for a while (friction less environ)
I´ll see if I can lock those balls
LarryC
Quote from: eisenficker2000 on April 12, 2009, 06:35:18 PM
After reading the patent; hockeysticks  and ellipse..
I'm glad you're showing the upper left quadrant closer to the video. The guides need to allow the weights to be freely thrown outward, varying due to centrifugal force based on rpm. The centrifugal slam at the outside edge of the hockeysticks is where the acceleration is coming from.
Regards, Larry
