MylowHJ Replication - Discussion
Started by wattsup, April 04, 2009, 08:49:58 PM
Lakes
Quote from: robbie47 on April 12, 2009, 03:46:30 AM
Last night I stubled upon flux measurments that can be done quite easy by a using hall sensor.
Would it be an idea to put two hall sensors on the stator magnet, one at each end.
Voltage of these sensors could be measured by a sound card input (two channels) of a PC.
In this way one could easily get more insight in the field alteration of such setup.
p.s. I will do a bit more research later on to show how this can be done easiest.
( have to visit family today).
Posted in the other thread.. http://zedomax.com/blog/2007/04/11/diy-circuit-hack-how-to-build-an-inexpensive-hall-effect-gaussmeter/
Lakes
Instead of using platters, how about this instead?
Chase212327
Queue,
I don't think adding more spindles, platters or maybe even more rotors will help solve this "closing the loop" problem.  I'm pretty sure all that may make it even worse. This is because I believe that the reason builders haven't been able to close the wheel is primarily because of what's referred to as "moment of inertia".
More here...
http://en.wikipedia.org/wiki/Moment_of_inertia#Overview
http://www.howeverythingworks.org/page1.php?QNum=55
"Moment of inertia embodies both mass and its distribution about the axis of rotation. The more of the mass that is located far from the axis of rotation, the larger the moment of inertia. For example, a ball of dough is much easier to spin than a disk-shaped pizza, because the latter has its mass far from the axis of rotation."
This is why your wheel is not picking up as much speed now, with so much additional weight to move (far from the axis).  It's no longer light enough to gain enough speed to easily glide all that mass half a platter to the next rotor set.
I believe the best way to overcome this is to add more stator magnets.  Could be that you don’t even need to add more rotors (mass) to the outside of the wheel, which would make it even heavier (far from the axis).
Think of a merry-go-round full of kids on a playground.  You need more moms to get it spinning faster.  Not more kids on the merry-go-round.
Also, it seems that there is a sweet spot to the distance of the stator magnet to the rotors, to keep it from being "sticky" (etc.).  When you load up the wheel with rotors and increase its mass, add more stators at that same optimal distance, also at different positions within rotor sets throughout the wheel.
Chase212327
ALFPARTS
Quote from: Michelinho on April 05, 2009, 08:37:02 PM
Hi everyone,
@ Hans, it looks a lot more like Tesla's homopolar generator with 2 disks (bifilar homopolar generator) where the disks are coupled by their circumferences with a conductive belt.
One thing that is so big that I did not see (and was told) and I have to share. Howard Johnson's Stonehenge motor does not rotate a disk but it rotates the stator as in Mylow's and Queue's replications. He also uses both ends repulsive force (1 magnet structure at each end of the arm) to achieve this. Maybe something interesting would be seen as rotational speed and stability of rotation.
Take care,
Michel
Edit: Each time we deviate from the original, we add complexity and difficulties.
And this is exactly what has been done. The Mylow Motor version of Howard's design in no real way even comes close to approximating the original concept. The C shaped magnet though it may work is not the way to go. Think 'flat' guys. But you watch. I bet I will not get onne single reply to this thread.
chrisC
Quote from: ALFPARTS on April 18, 2009, 05:36:00 PM
See TK's more than successful MyLow replication!
http://www.youtube.com/user/TinselKoala
cheers
chrisC
