Permanent magnets and the electromagnet
Started by pinestone, April 10, 2009, 10:48:22 AM
pinestone
With the help of my brother-in-law, I now have a small & powerful Bedini motor charging an almost dead 12V battery.
At some point during our experiments, he put a 1.2 T cylinder magnet on the end of the pulse coil's core. (opposite of the rotor end). The rotor increases its speed about 20%. If we add 2 more magnets at 90 degrees to the core at the same end, the rotor more than doubles its rotational speed.
see: http://www.nanomagnetics.us/projects/bedini%20motor/bedini%20w-magnets.jpg
Polarity matters. The fields are in repulsion (*corrected), and if we reverse the polarity, the motor slows down.
Has anyone else tried this?
I've made some tests and taken pix...maybe someone would care to comment.
The oscilloscope shows the waveform at the charge point. The frequency counter shows the input coil pulses and the meter indicates total current draw through the transistor.
Since my rotor has 3 magnets, the indicated frequency must be divided by 3 and multiplied by 60 to get RPM's.
First pix, no magnets: http://www.nanomagnetics.us/projects/bedini%20motor/1bedini%20no%20magnets.jpg
280 mA @ 1160 RPM
Second pix: 1 magnet: http://www.nanomagnetics.us/projects/bedini%20motor/1bedini%20w-one%20magnet.jpg
320 mA @ 1960 RPM
Third pix: 2 magnets: http://www.nanomagnetics.us/projects/bedini%20motor/1bedini%20w-two%20magnets.jpg
360 mA @ 2780 RPM
Fourth pix: 3 magnets: http://www.nanomagnetics.us/projects/bedini%20motor/1bedini%20w-three%20magnets.jpg
370 mA @ 3300 RPM
* I made a polarity correction.
WTF???
pinestone
Well, I think I've figured it out. Someone let me know if this makes sense.
Normally, the rotor magnets are attracted to the steel core. There is a lot of rotational resistance due to the strong attraction.
By placing magnets on the opposite side of the steel core, a huge amount of repulsion appears on the rotor side of the steel core. This results in a minimum amount of 'stick' and the rotor can spin up faster with much less resistance.
pinestone
akunkeji
Michelinho
Hi pinestone,
Nicely done. You could also use copper around your coil to get a stronger pulse from your electromagnet. The coil must be fairly flat though. That principle is used in transformers.
Take care,
Michel
