TRI GATE TRY ---- Check this video out ----
Started by magnetman12003, April 11, 2009, 08:39:07 AM
Low-Q
Quote from: magnetman12003 on April 13, 2009, 12:05:51 AM
Hi,
I am going on vacation tomorrow -will do the movie later.    The below link by Clanzer inspired me to build the Tri gate setup I have shown.
http://www.youtube.com/watch?v=S2pNehGPWvw&feature=related
If 33 linear gates can be cleared with a finger lift thats proof enough for me that magnetic energy can be harnesed.  Now all we have to do is somehow arrange magnets to maximize  power in a rotary fashion.  What I have shown is real weak but I think its a step in the right direction. You must use a very low friction bearing and a perfectly level surface to see if you are acually doing work with the magnets.  The real trick is to make a wide neutral spot in the stator so we have an area that devides the pull from the push.  The inertia of the flywheel also helps do both however if its to heavy it hinders.  Everything is a real juggling act.
If you could make this video available world wide, so I could see it? I just got the message "This video is not available for your country"
Vidar
magnetman12003
Hi All,
I was going to make a movie but whats the sense just to see it slow down and eventually stop.
I just posted new info in the Overunity uk group that look real promising. Check out my LATEST posting there.
The basic idea acually works for me.  I experimented with it quite a bit.  As far as I know it has never been tryed before as it involves movement only using the magnetic flux in a IRON rod..
Worth looking into.  Real inexpensive to try out.
magnetman12003
Quote from: magnetman12003 on April 12, 2009, 10:26:47 AM
I will do that but I am going on a short vacation.
Sometime next week I will make that video.
I just posted new info in the below forum.  Check it out.
http://www.overunity.org.uk/forumdisplay.php?f=31
gyulasun
magnetman12003
