Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
powercat
powercat
Tommey Reed
Hi Cat,
I am working on the second stage to loop the pulse generator.
This will prove OverUnity.
The BEMF cant be loop, because of the caps need to have 12v constant charge, when the cap drops below 12v the pwm have problems sending the right amount of voltage to the coil.
Almost have to be regulated to work overunity, As for input of 12v power having a constant output, It does show overunity.
Tom
powercat
Hi Tom
did you see the suggestion made by gyulasun
the most convincing proof for any extra output over an input would be using a DC-DC converter to loop back the output to the input.  (Off the shelf  DC-DC converters are available with many input -output voltage/current ranges, with at least a decent 70-80% efficiency or higher.)
End Quote
I'm sure other suggestions will come in time
looping is big problem, and one of the best I have seen is the two battery system[Bedini]
sorry but with my limited experience I can only suggest things I've seen here before
cat
powercat
Tom
Do you have any measurements that you could post on your current setup showing OU
Thanks if you can
cat
