Does a proven working TPU device exist at this time?
Started by AquariuZ, April 17, 2009, 08:47:22 AM
MACEDONIA CD
ZDRAVO OTTO  ZELIM TI UGODAN ODMOR   NO IZGLEDA NEMAS ODMORA OD  ...
LJUDI SAMO PITAJU  A STA JE  NEGATIVAN OTPOR  PA AKO ZELIS  POSTO TI SI NA ODMORU JA  CU IM KAZATI AKO NEMAS NISTO PROTIV  ;)
AND I WHILL SAY SOMETHING LIKE ANSFERING  OTTO  <NEGATIVE RESIST >
BUT FIRST I LIKE TO MAKE CLEAR HERE
ALL
TPU FROM S.M IS DIFERENT  BUT THE RESOLTS IS THE SAME
FINAL BIG TPU OF S.M IS  PRODUCED NEGATIVE RESISIT OR LOADS
BUT FIRST  TPU SMALL IS NOT HAVE NEGATIVE RESISIT  BUT ONLY ,VORTEX """"""" TO HAVE OUT POWER
IF YOU TAKE SIMPLE  <,THE NEGATIVE RESIST  WHILL BE   ABOUT 1 TO  10000 OR MAYBE MORE
AND NOW   HERE IS ANSFER
IF YOU  LEARN THEN YOU WHILL BE EASY TO ANDERSTEND
SAMO NAPRED OTTO <
PITAM SE  KOJI CES TPU PRVO URADITI ONO SA  NEGATIVE RESIST ILI  VORTEX
<S.M >SOME MASEGE TO MANNIX
...i have hear that some one old video  of s.m whit compass insaid ccenter  has fast spinig
but if the tpu produced  infinyty speed then the spinig of compass whill stop
and then tpu whill not have  out energy  if is the spining whill be to fast
ansfer ...is beacouse the  invisible elktromagnet lines  whill not whill be cuting  of the  ???? and no energy
I LIKE TO SEE  ,PROF . ANSFERS  FROM YOU HERE  OF THIS
WAY
turbo
sì bene se stiamo andando parlare tutte le lingue differenti nello stesso filetto, come il della MACEDONIA CD, quindi voi può essere it' sicuro; s che va essere un grande disordine!
Marcos.
MACEDONIA CD
wooooooooooooow  @marco  dont tell nothing for me  beacouse  people  he know about me   <<AND PEOPLE  HE KNOW ABOUT YOU  WHAT A PERSON YOU ARE  >>YOULIKE TO  BRING PEOPLE TO DOWN  WHIT YOU  TO MUCH RESPESPEKT  ITS SEFL
BUT  PEOPLE  IS KNOW  THAT YOU HAVE NOTHING AND  STILL YOU DONT REMEMBER THAT  YOU MAST CHANGE  YOU  TALKING  FOR YOUR <BON TON>
BUT  YOU STILL ARE  NO GOOD  PERSON  >.AND THAT IS REASON WAY  FORUM MAN DONT LIKE YOU
YOU THINGIF YOU ARE LIVING IN WEST AND YOU HAVE ARE GOOD  PAYMET  AND  THE KNOLEGE  IS  FOR YOU  <<BUT YOU ARE VRONG
WHEN YOU WHILL ANDERSTEND THAT PLEASE  GROVING  UP
YOU KNOW THAT IM BETER THEN YOU
AND THAT IS REASON  WAY  YOU ALL TIME  HIT ME AND PUT ME DOWN  IF MY ENGILSH IS LOW  THAT IS NOT MEANING THAT I DONT KNOW   <YOU KNOW THAT VERY GOOD >.IM BETER THEN YOU AND I HAVE  BETER SETUPS THEN YOU  JUST STOP  WHIT  HIT PEOPLE HERE
TIME WHILL CAME  HERE WHEN I WHILL SEND SOME STUFF AND  YOU  WHIL BE SHAME ON YOU TO SAY SOMETHING FOR ME
BUT  YOU MAST  BE TAKE SERIOSE CHANGES   HERE IN FORUM
BEP
Quote from: otto on May 01, 2009, 06:48:31 AM
Hello all,
can somebody give me an idea how to shield a TPU??
Im the last 10 days on vacation, working more then 10 hours a day and I dont feel good anymore. Im measuring around my TPU over 3kV in the air. Every day I have more and more trouble with my health.
Otto
@Otto
If the problem is common EM fields then a simple Faraday cage will help. Just make sure all seems are good electrical connections and the cage is well Earthed.
Should the problem be the other way put solid mass between you and the TPU. The more solid and thicker the better. Distance helps a bit here, as well.
I don't know what your TPU could be radiating but you should check all possibilities before long. If you awake with white spots in your vision, headaches, nausea, etc. You should stop and fix the problem.
Repeated small EMP can also cause confusion and lethargy. Don't let it go that far.
