Thanks to ALL for your help!!
For those of you that missed 60 minutes Cold Fusion
Started by cwstang, April 19, 2009, 10:36:36 PM
d3adp00l
I would love to see a system running with power output.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
AbbaRue
I got some Tungsten welding rods 3 years ago and built a test unit based on the info from JLN.
I used water and baking soda and I used a half wave voltage doubler to step up 120V to 240V.
I used 470MFD 400V caps and 1000V 6A diodes for the voltage doubler circuit.
I got a lot of heat energy out of the unit but I discovered the tungsten was being consumed very quickly.
I think this has a lot to do with browns gas and the way it burns tungsten.
Anyway I burned away about 2 inches of tungsten welding rod in about 30 minutes.
At about 50 cents an inch for tungsten, I concluded this was not a viable energy source.
It is much cheaper to make bingo fuel and use that to run a generator.
Carbon rods are about 50 cents a foot and will give you much more heat energy then the tungsten rods.
And you can produce enough bingo fuel from a car's alternator in real time to keep the car going.
Heating a home with it would be very efficient as well.
jadaro2600
..interesting, but what happens to the deuterium? ..still there is fuel!
Anyway, ...the idea is nice.  I'm just flustered by the cost of Palladium!
triffid
The metal "nickel "might take the place of palladium in these experiments.Its in the same column on the atomic chart as platinum and palladium.As far as I know no one has done any CF work using nickel.Metals in the same column on the atomic chart have similar properties.So someone should try nickel.Its a lot cheaper than the other two.triffid
triffid
When news of CF came out in 1989,I knew it would be crushed for now.So I collected all the info on it from the newspapers I could and put it in a scrapbook.It most likely will be 50 years before we are allowed to have it.Triffid
