Cooking with HHO , my experiments so far
Started by jdcmusicman, April 23, 2009, 01:58:12 AM
triffid
It may take a couple of days to see bubbles.Triffid
triffid
So no more posts here?I was serious about what I said here.There was even a patent granted on it back in the 1930's.Off and on like twice since then someone published a small article about a  couple of magnets generating HHO without current.I did the experiment myself.I soon found out that a small current was being generated between the two magnets.I was jumping up and down when I first saw the bubbles streaming.When I noticed that one magnet's nickle plating was coming off.I knew I had a battery action going on here.Triffid
jdcmusicman
triffid...
Hey man that is very interesting , sorry it took so long to respond I been busy..
So from what you are saying you can have 2 magnets generate its on electric and produce hho at the same time ...
Sounds almost to good to be true.
Could you fill me in on any specific ways to replicate this ..
I do not know when I will have time to but I would like to replicate this idea of yours....Thanks for the post
Jdcmusicman
Mark69
I am still following yours posts as well.  This site's new format makes it a lot harder to follow posts then before.  The home page is too busy and any older posts get pushed off the screen.  I do not like the new format of this site.
Mark
triffid
I had two nickle plated super magnets on hand.I placed them at the bottom of the plastic fork.They were kept apart(never touching).But the liquid was able to surround them when I put the whole thing in the electrolyte.For electroyte I used vineagar or baking soda solution.Never,never,never use salt solution.If you use table salt you are making CHLORINE gas and hydrogen gas.After I placed the plastic fork/both magnets into the electrolyte.I had to wait two days to see the bubbles.I was real happy at first but when one magnet started to corrode.I knew a weak electric current was being generated.Still the water breaks apart more quickly when the magnets are present.I would guess the voltage being generated was on the order of 1/10 volt.Not much in the way of amps maybe.I found it worked better using white vinegar straight out of the bottle.The baking soda solution worked too but had fewer bubbles.So I think of it as having an internal battery.This produces some bubbles but not a lot.Enough to see and get excited.Tiffid
