Cold Electricity
Started by gravityblock, April 30, 2009, 01:11:26 AM
ramset
Its how I made my living In NYC
Selling the Guns that shot  together steel and concrete,
"Ramset" guns,
Any other questions?
Chet
Thanks Grandma
sigma16
Quote from: ramset on September 09, 2010, 04:40:27 PM
Chet
A wealth of information has been dumped across this forum.
What do you do with it?  I don't see that you ever build and experiment.
ramset
Shame on me then!
I'm trying to do something about that,I don't work in the
Field and only recently have grown to understand enough that I could experiment and actually learn/do something.
This post by The guy with the big head is more of what we need around here
Sigma16, Here are some thoughts on electricity and free energy. You may be one of the few around here that could understand it.
I found a paper relating to our PM's on this subject earlier today - I may have given you this paper in the past but it explains why the current appears in the core.  I didn't bring this up as I have over 10MB of science papers on my computer and was not sure I would be able to find this one.
The emission people call cold electricity is the splatter that occurs during the initiation of AB effect in the FE when the particle pieces clap back together. The particle is slapped back together with the speed and pressure of the universe and is where acceleration / cavitation / electron cascade takes place. (BETA emission) It is also what creates voltage and moves it at the speed of light.
While the mass or larger quarks are still probably present and reform, their mass is reduced and proof of that is action at a distance. You can't have it without mass in between.
The image below is the last page, do you have this paper? NOTE the orange outlined area. I don't want to upload the paper since I may have purchased it and it is copyrighted. PM me an email and I will send you my copy. I think I alluded to the AB effect in an early post on this cold electricity subject.
Understanding that AB effect opens the door to understanding electricity itself which most have no clue about and is often referred to as a phenomenon. http://en.wikipedia.org/wiki/Electrical_phenomena
Below is reason that I make the claim that electricity itself is mass to atomic energy conversion. Accelerate it to the next higher order and OU is possible. What is an order? Electrons flow down a copper wire at less than 1 meter per minute. E=MC2 is the equation. Move that electron at just under two meters per minute and you get to roughly square the energy output.
When you stop and think about it, you would need a particle smaller than an electron to shield a spin curl wave since the aether vortex is made of particles much smaller than an electron and can easily slip between the atoms that make up the shield regardless of the size of the atom or length of the lattice chains.
Now take that a step further and ask yourself does AB effect and associated spin curl occur on the surface of conductors as well as inductors and does that account for the right thumb rule? Me thinks it does and explains current at a nice simple level. Ironic that half a spin curl wave looks exactly like a current in a river isn't it?
A spin curl is really two waves like two tornadoes tip to tip - one north negative and one south positive. (Look at a black hole photo from Hubble)  If you assume that one side of the spin curl dips into the wire and the other side is above the surface, then that would explain why a superconductor works. Since the metal's lattice is very dense, half the wave can't sink into the conductor and so the charge carrier flows freely on the surface and no friction is produced. It also explains right thumb rule for current flow.
The reason that the spin curl is not persistent on a non-superconducting conductor is one side of the wave is below the surface of the copper and is instantly destroyed upon cessation of voltage flow and you can't have a ying without a yang.
I will add to that that reason the spin curl develops is that all mass is spinning. When you divide a particle which is what AB effect is, the two halves will never be equal in their new spin rate, velocity, direction or size. Due to the gravity and magnetic fields of the particle pieces and the fact that they fit together like a lock and key they come back together on the other side of the dividing particle.
Now since they are not spinning equally they need time to sync and reform, this is what produces the persistence. It is also the reason that it is said that all quarks or pieces of a quark have a unique personality.
However, just like throwing a snowball at the blade of a knife, some of that snowball will stick to the knife and some of it will splatter. The splatter is cold electricity but it is not being formed using AB effect per se in an arc, it is being done through fusion in an electrical arc. If your body becomes the FE core, and your blood is filled with iron, the iron in your blood becomes the dividing magnetic particle of the core and you just got electrocuted at a cellular level.
Voltage and current flow speed - Voltage is caused by the two parts slapping back together at the pressure of the universe with is the speed of light. Current flow is less than 1 meter per minute due to spin curl persistence. Until the particle reforms, it is not going anywhere in a hurry. Since it can't be well shielded this also means that the magnet also can't have much action on it at a distance.
Now take that and have a look at the double slit experiment. Suddenly every behavior of that experiment is explainable and predictable and the subject of quantum science is relegated to the trash can. Quarks are quarks and it matters not if they are electrons, photons, etc.
Static electricity - Just little pieces of particles that have a balanced or weak magnetic charge. I think of it as quantum dust. You can recombine the pieces back into heavier particles using a magnet - see methernitha. Note that the two halves of the coils are connected at the top. The reverse of AB effect? Notice how the Methernitha state that the static is recirculated around the device to make the current heavier?
Sparks claimed that their was 1 ma of current in a 1st orbit electron. I suspect that number flawed  but have not done the math yet. I tried to get him to do part of it for me to no avail. F'ing worthless homo Wilby went and pissed everyone off.
Anyway - those are the high points and things like Aether, spin curl, current direction, current and voltage speed all start to make sense. Oh yeah.. the fuel source and conversion of true OU free energy devices too.
Hope that post is understandable. It is the first time I have shared that info. or tried to put it into words. Look at the original AB experiment for better understanding. I played with the experiment 10 years ago after stumbling across a paper of AB effect. (Electron stream, two reflectors, brass mesh, solonoid coil, wedge shaped magnet)
The info. is way over most peoples heads and those that could understand it would have to let go of a bunch of belief that they paid lots of money to get in college. Finding people smart or sane enough to discuss it is difficult so I have always kept it to myself.
Conversely, if I try and discuss this type of info. on a physics forum, I get banned by the educated magical thinkers because nobody has told them it is OK to believe this information through peer review. Peer review is all about suppression. So I am stuck, living in reality mostly alone but that beats the hell out of the alternative of being one of them any day!
The sane persons thought filter:
1.Knowledge is experience.
2. There are things that I know and things that I do not know.
3. I don't know what I don't know.
Use the mathematical law of probability to derive truth. When so many pieces begin to fit, it is probably true.
The experiments have been done. The devices have been invented and built. The science papers have been written and peer reviewed by some of the smartest people in history like David Bohm and Maxwell. All you have to do is connect the dots.
People like Wilby are so focused on hiding their insecurity they don't know that there are dots out there to connect and they are not here to do that anyway. He is here to false try and affirm to himself he is not an insecure moron. A lifetime of hyperfocus on his hiding his insecurity meant he missed learning a whole bunch of things out here in reality.
It is a character flaw that occurs when it matters more to him what other people think of him than he does of himself even though he uses deception to attempt to fool others. The problem is that the only people he fools are other people like him. That is what produces the mob mentality that stupid people exhibit and the reason they will gang up on others in packs. It is all based in insecurity. Got tiny man junk?
Thanks Grandma
quarktoo
Here is some of what I have read on the subject. The 13th tribe has a lot of info. on this subject which has nothing to do with free energy.
The AshkeNAZI jews are not semites. They were phallic worshipers from the region of Georgia. Around the year 700 AD their king grew tired of the incest and chose at random from the three great religions. Judaism won and he brought in rabbis to convert them.
From there they migrated to Germany,  Poland and Hungary (around 100,000 people). After WWII which was actually started by them and funded by Ashkenazi Zionist Jews from around the world, they migrated to Palestine and formed Israel.
http://www.guardian.co.uk/world/2004/sep/25/usa.secondworldwar
It appears the Jews, gypsies and blacks were placed in the labor camps to sort them out and kill the non Jews and purify the Ashkenazi race. The Jews didn't die in large numbers until the end of the war after the US bombed the supply lines and they starved.
Some say they were placed in the camps to keep them out of the war and safe since they were paid and have everything from entertainment to  wwhore houses.
At a big picture level, some claim that creation of the state of Israel was the objective behind WWI and WWII and in order to do that Germany had to be taken down to break the military alliance between Germany and Turkey who controlled Palestine.
One thing that is for certain is the Bush family lost their assets under the trading with the enemy act and the money was returned after the war.
So like any war, an inside job started by a terrorist act of attacking themselves by a tiny group of people that have no borders.
The Red Cross documented 271,000 Jews died during WWII. The 6 million stuff didn't start to circulate until around 1962 and was propaganda used after WWI according to people knowledgeable on the subject.
What is true has been so blurred by propaganda and lies that it is difficult to prove anything.
Odd that most people don't know that the Bush family working under Rockafeller, funded Hitler and built 6 labor camps during WWII. That should give you an idea of how much power they have had in the US since zionism was founded in 1898.
Here in the US they dominate most segments of society such as medicine, banking, legal system, medical system, etc. Once they formed the Federal reserve, they were able to inflate money and control anything. The IRS is also a private corporation owned by them and registered in Peurto Rico. It is the collection arm of Rothschild's bank.
Dr. Fishbaine who owned all shares in the corporation called the american medical association (AMA), sued many of the inventors of cures for disease until they gave up or were murdered. One of those people was Dr. Royal Raymond Rife who used cold electricity to cure nearly all disease.
http://www.rife.org/
It can be accurately stated that nobody has murdered more people for money and race in history then the AMA. That includes all wars combined.
Dr. Yale and others replicated the work of Rife who was a true genius. Rife found that by shattering quarks, be could refract them off a object as small as a virus and magnify optically over 400,000 times. Normally you would be limited to 2000X due to the fact that the light wave is larger than what you are trying to refract it off of. (Abby limit)
Rife then recombined the unique personalities of the quark fragments in a prismatic lens system which is the optical equivalent of photonic AB effect. I alluded to this in my previous lengthy post regarding double slit experiment.
To combine all Jews into one lump is racist and wrong. You will never defeat the enemy of humanity by becoming the enemy of humanity. In the end, if your love or is greater than your fear, you will go forth and multiply and at the end of the 4th root race, the love of the gentile has dwarfed the fear of the Jews.
quarktoo
Quote from: sigma16 on September 09, 2010, 04:33:57 PM
Why the userame "ramset"?
It is a nautical term used to set a cannonball in a ships cannon. He is part of the mossad crew that chose nautical terms as names. Intel loves their little riddles.
Ramset lubricates and then others show up to irritate. In the process of this push pull, they get you to spill what you know so they can determine if you should be suppressed.
Ramset has no clue what I know but he does enjoy my humor and as long as he is pleasant, I enjoy making him laugh. I wouldn't trust him as far as I could throw him but that would be true of anybody I find here. He will stab you in the back in a New York Second but then he is a New York Jew originally but claims he moved to Connecticut.
Trust me, I don't take anything here personally and could not care what his race or religion is or who he is working for. You are all spooks to me.
