Thanks to ALL for your help!!
Cold Electricity
Started by gravityblock, April 30, 2009, 01:11:26 AM
ramset
Marco
thankyou
Wings
WOOOOOOW!!!
Thanks
Chet
Thanks Grandma
gravityblock
Quote from: -[marco]- on April 30, 2009, 04:14:01 AM
Cold electricity is TRUE electricity.
It is the real power without electron flow.
This type of electricity was shown to us by Mr.Tesla over 100 years ago.
The electrons are simply "dragged" by this Cold electricity flow and this creates what we see as resistance.
And this is also the reason why conventional electricity shows up on our meters.
We can measure resistance, but True Cold electricity does not show up on our meters, because there is no electron flow, yet it can burn a filament bulb on one wire.
In conventional electricity, the dragging electrons , create the magnetic field and, these two go hand in hand.
This is the reason why we won't find any OU in magnetics.
The magnetic fields are caused by the dragging electrons, which in turn are a secondary effect of this primary True Cold Electricity flow.
You can't tap something secondary without the primary part that caused it...
For some people, all this is well understood, but for the most part, people are still thinking electricity is electron flow and even our teachers tell us it is.
Marco
You first say that cold electricity drags the electrons, then you say at the end, electricity is not electron flow.  You also said true cold electricity is without electron flow and it can burn a filament bulb on one wire.  Doesn't the wire that is being burned from the cold electricity have free electrons in it, that would be dragged by this cold electricity in order to cause the bulb to light?    Replace those filament wires with a wire that doesn't have free electrons and see if the bulb lights with either cold electricity or "true cold electricity", since according to you, electricity isn't electron flow.
Cold electricity is a negative time flow of electrons while hot electricity is a forward time flow of electrons.  Until people recognize time as being a factor and stop considering it as a measurement only, this will never be understood.
Without time, energy can not be released or converted from one form to another.  An aether unit is composed of forward and negative time.  This is where the electrons gets it's energy in order to maintain it's own magnetic field.
Cold electricity does register on our instruments as BEMF since it is flowing in negative time or flowing backwards.  There is a difference between BEMF and cold electricity, but we will see cold electricity on our instruments as BEMF.
"Stolen waters are sweet and bread eaten in secret is pleasant"
turbo
So it seems Cold Electricity has more meanings to diffrent people.
Same thing happens with Bemf or Back Emf.
Some people say the Bemf is simply the spike which is seen comming from a coil when power is switched off, and others believe Bemf happens whenever the field strength increases or decreases...
It has been shown to us by Mr.Tesla that his form of Cold Electricity is what is called a massless current.
This means without electron movement since electrons seem to have mass.
Because or this it can go faster, much faster, far beyond lightspeed.
However ,backwards is a diffrent thing.
There are several people who have replicated some of Tesla's work and they all agree the electrons get "choked" inside the coils along the way ,and thus only real massless current can pass.
This behaves diffrent then conventional electricity because it will seek it's way along dielectric paths ignoring short circuits.
There are several setups which show these behaviours.
For example if you read Mr. Eric P. Dollard's book "Condensed intro into Tesla Transformers, you will find setups that produce this form of electricity.
Take a close look at figure 4 which is the balanced coil system.
It encounters segments of coils which have a direct relationship to the total wavelength of all coils toghether.
I won't go into detail, just read the literature and do the tests if you want to find out the real nature of the beast.
Marco.
Grumpy
Quote from: gravityblock on April 30, 2009, 01:30:45 PM
When a bulb is lit with cold electricity, is it lit because of the wire or the parameters of the space around the wire?  If just a wire then a filament should glow outside of the bulb.
If reverse time has anything to do with it, then how can we experience it in forward time?
        -Frank Edwards
gravityblock
Quote from: Grumpy on April 30, 2009, 03:36:40 PM
We experience it in forward time as BEMF that runs cool and not hot.
