LaFonte Equilibrium Motor
Started by Butch LaFonte, April 05, 2005, 12:10:18 AM
Butch LaFonte
http://butchlafonte.50megs.com/  till new site is up and running.
New paying web site being build at this time that will have latest updates on the Equilibrium Motor,
test data, and a video, plus in time all more than 1200 past design idea drawings from the last twenty five years.
The new site address when operating will be butchlafonte.com
Thanks,
Butch LaFonte
Butch LaFonte
Norman and all,
The Equilibrium Motor can be configured using two magneto's, one in repulsion and one in attraction. The present design excludes cores in the coils because they complicate the setup due to domains having to be reversed and the rotor magnet wanting to stick to the coil cores which complicates balancing the repulsion and attraction force and EMF forces. The air core design operates in a NEAR magneto way because the voltage/current stays stable during the rotor movement away from the locked rotor/stator and the air core coils act as permanent magnets because their strength stays constant through the rotor exit, no generator drag. One coil tries to act as a generator, the other as a motor, but any EMF they produce is cancelled by each other so the coils just act like permanent magnets due to the steady main voltage/current source. This source energy is recycled or used for other existing needs. The coils try but never are able to function like a generator, or the other like a motor. The mail power supply to a degree never knows what is going on with the rotor, it is kind of like a team of 1000 horses pulling in a straight line, one horse tries to slow down, the horse in front of him tries to speed up, and the total pull of the team stays the same through it all.
What is interesting to see is what happens when you take one of the coils out of the circuit and move the rotor away from the fixed magnet and watch the volt meter peg to one side. Then take the other out and put the first back in the circuit and see the same thing except the voltage is in the opposite direction. Now put the two back in the circuit and watch the meter needle stay almost still when you move the rotor away. They cancel each out, making the coils act like permanent magnets.
Butch
PS Please read the operation sequence on my site,
cmichaelcouch
Butch:
Just wanted to encourage you since the new group host switch thing.  It's not as easy to find everything as it was in the digest format but this may be good too.
Michael Couch
hartiberlin
Hi Michael, here we have a ver nice search function, so this will
find everything already posted. Much better as in the Yahoogroup.
Butch, are you sure that your action and reaction coils will not all
cancel out ?
Did you get the parts from Norman Bollinger to finally build some
prototype, which the father of Dave Squires did for you ?
Regards, Stefan.
Butch LaFonte
Stefan,
I will post links to pics on the web.
Butch
