!ST/MK1 PULSE MOTOR/GENERATOR DEVICE...
Started by innovation_station, May 06, 2009, 08:41:42 AM
innovation_station
HERE IS AN UPDATE...
THIS UNIT HAS RAN 20 HOURS  TOTAL...  I TOOK A READING ON MY INPUT BATTERY AFTER 20HOUR RUN THIS MESURMENT WAS TAKEN WHEN IT WAS IN OPERATION SO IT IS POWERING THE MOTOR AND MY INPUT BATTERY READS 12.2V STILL.... AND MY BATTERY BANK IS CHARGEING AT 36.7VDC WHEN AT REST IT READS 36VDC ...
SO
I WILL ADD THE NEXT 4 MAGNETS AND SEE WHAT WILL BE ....  ;D
IST!
innovation_station
I ADDED THE NEXT 4 MAGNETS ALL N FACEING OUT ...
RPM INCREASES ...  TORQUE IS MORE ASWELL
WHEN IT IS AT REST MY BANK READS 36.4 VDC IT HAS RAN ABOUT 30 HOURS IN TOTAL...
SUPPLY BATTERY AT REST READS ...  12VDC  AFTER 30 HOURS OF RUN
SO I GUESS IM NOT LOOSEING TOO MUCH ....
AGIN IM ONLY USEING 1 COIL.....
I WOULD EXPECT MY CHARGE TIME TO REDUCE AS I ADD THE REST OF THE COILS ...
IST!
innovation_station
SO IT LOOKS LIKE THE CAIN REACTION EFFECT ...  :o
MEANING  CURCUIT COIL CAP REPETE ....   CURCUIT COIL CAP ....
WELL I HAVE IMPROVED THE PULSE COILS THEY SHOULD BE TRFILLAR AT A MIN ...
REASON ..   PULSE COIL TRIGGER COIL GENERATOR COIL ...  OR IF YOU HAVE REED SWITCHES ... USE BIFILLAR COIL ....   IM ALL OUT OF REEDS I BURNT THEM ALL UP ... THEY WERE RATED AT 4 AMP....  MOST I EVER USED ON THEM WAS 12 DC 1 AMP...  I GUESS THERE IS YOUR PROOF OF FREE ENGERY WHEN YOU WELD THE REEDS ... RATED AT 4 AMP...   ;D
LOL
SO IF YOU USE  A TRFILLAR COIL  YOU WILL HAVE A GENERATOR WINDING  INTANGLED WITH PULSE AND TRIGGER  ..  SHAREING THE SAME CORE ...  :P
THEN YOU HAVE CARRY ON  RUN TIME POWER FROM THE GENNY WINDINGS ... AND STILL GET THE COLAPSE ... TO GROUP AS 1 ...
FOR OUTPUT
IST!
innovation_station
WELL ITS COMEING ON 40 HOURS RUN TIME ... NOW AND I JUST TOOK A MESUREMENT ... ON THE SUPPLY BATTERY WERE DOWN TO 11.5 VDC UNDER LOAD ...
SO LOOKS LIKE IM DROPING .5 VOLTS EVERY 20 HOURS ON THE SUPPLY BATTERY ...
THE BANK READS 37 VDC CHARGE ... AT REST  IT READS 36.4 VDC ..
IST
innovation_station
WELL LOOKS LIKE THE INPUT BATTERY WENT DEAD ....   WELL IT WAS STILL DRIVEING THE MOTOR BUT NOT TO THE SPEED I DESIRE ...
SO I HOOKED UP THE CHARGER AGIN TO IT TO CHARGE IT FOR THE SECOND TIME
THE MOTOR RUNS WILE THE BATTERY IS BEING CHARGED IT IS AN AUTOMATIC CHARGER AT 12VDC 10 AMP
IT SHUTS OFF WHEN ITS JOB IS DONE ...
MY BANK IS NOW CHARGEING AT 37.2 VDC  IT HAS BEEN BOUT 42 HOURS TO 1 CHARGE  OF THE SUPPLY BATTERY ...
IST
