Found TPU from google
Started by asupawat, May 16, 2009, 10:20:58 PM
Bruce_TPU
Quote from: EMdevices on June 14, 2009, 07:23:01 PM
Lindsay, are those Dave's videos?     (sorry I don't know Russian and I can't navigate those webpages to see the videos)
EM
Yes.  It is pretty funny!  LOL    ;D
the_big_m_in_ok
Quote from: asupawat on May 16, 2009, 10:20:58 PM
I think this is not Steven Marks build.
http://narod.ru/disk/5728463000/TPU_Home_01.avi.html
http://narod.ru/disk/5728466000/TPU_Home_02.avi.html
http://narod.ru/disk/5728470000/TPU_Home_03.avi.html
http://narod.ru/disk/5728472000/TPU_Home_04.avi.html
>>Sorry to say, but the whole site is in Russian Cyrillic.  I couldn't download anything to my borrowed computer's monitor.  I didn't think they wanted Euros to allow for their commercial, professional support of their site.  I think.
--Lee
rtl8186
Hi !
Is really TPU,on video Steven Mark or man why build work device!  This video on site http://www.matri-x.ru/video.shtml
This site FOR PEOPLE! NO commercial ghosts !!
I ordinary man,why try to build TPU for personal use!
the_big_m_in_ok
rtl8186 said:
Hi !
Okay, I believe you.  Even of the whole site is written in Russian (it is), I could finally get to the point to where the server in Russia was asking the typical Windows dialog box question:  "What application software do you want to open the file with?"  I understood I needed a later, or new, Windoew Flash Player plugin to proceed with the download.  This computer doesn't have that.  I can get to a computer that does have the plugins, but not for a while.
So, you're correct, rtl8186, the video clips are free.  But, if a viewer doen't know Russian or have a complete suite of the newest software, it won't be helpful.
Very good!  I wish you success, but a better translation to different languages would assist those not familiar with Russian.
--Lee
IceStorm
Did you see the yellow/red filament when it disconnect the light bulb at the end ? light any light bulb, even a opaque one , you will still see a yellowish color at the end caused by the filament. Now look at where the filament is placed in a real light bulb and now look at 0:06 to 0:08 on the fist video, he connected the light bulb and disconnected it realy fast, you clearly see the light come from the base of the bulb and not from where it should be.
What you see is a LED inside a light bulb lol
Best regards,
IceStorm
