Mylow Motor was a fake
Started by hartiberlin, May 20, 2009, 07:43:27 AM
LightRider
TK, I may be in error, please correct me.
With a zoom on your graph here are some simple calculations...
on the assumption that the selected area is a zone of acceleration made from a hand.
on the assumption that this area corresponds to where you made the most carefulness for a smooth acceleration.
total length (between black lines at the beginning and the end) is => 100 sec.
total length is => 148 pixels
acceleration zone chosen is => 8 pixels
that give us:
acceleration zone chosen is => 5.4 sec
Thanks,
LightRider
EDIT:
IMAGE IS A ZOOM FROM TK ANALYSIS
http://www.overunity.com/index.php?topic=7486.msg182683#msg182683
wattsup
@LightRider
What you are probably looking at is exactly what is happening when the stator passes through a succession of rotors in three blotch three blotch three blotch three. If you passed the rotors through the stator slowly, the magnetic field exchanges could equal the advance and slow-down to advance-slow down in a continuous manner. These are all micro-movements with a forward momentum.
The whole succession could happen faster or slower, it does not matter. Even then, these magnetic influences will have their play on the movement of the wheel, hence on your graphic. Actually if your graphic is showing this effect, it is pretty incredible that you came up with this. Really good work in movement plotting.
Magnets are fast little buggers and mutual interaction is generally faster then the eye can see. So it is also evident in the micro time you are showing here. A magnet wheel cannot turn like a car wheel because a car wheel is turned by the axle power transfer, whereas a magnet wheel is turned by magnets. There is nothing linearly similar about these two ways of motive promotion, expect that to the naked eye, both are turning.
@All
For the Video 6 Hand Theory
Here we go if you want.
In visual evidence of Video 6, let's say, even though I could not detect any opportunity and/or I don't think Mylow pushed his wheel, because he knows the difference would have been noticed right away. He just let it go (because he knew it would turn - lol). But let's say Mylow had ONE shot to move this wheel by hand to make the wheel hold an immediate maximum rpm, because we all know a gradual acceleration with magnets is "impossible". How would the graphic have to look. Steep rise with very gradual decline? Now I know for a fact that the video dispels any possibility of doing this twice, or three times, so, let's just say he had one crack at it. Is it possible with one hand turn to make this effect. I doubt it. But let's put it out there and see what happens.
maryyugo
Quotenothing. you've avoided the question three times now, i know all i need to about you.
Sure you do-- you're psychic, I'm sure.
LightRider
(re-post from Howard Johnson Replication Tube Claim)
Mylow Video update
Youtube resolution...
(VIDEO ADD #7) How Mylow Replicated Howard Johnson's Magnet Motor
http://www.youtube.com/watch?v=gdrhFV8k-Nk
NOW IN HIGH-RES...
pre MIB high-res videos - One of the files is the "my lab" video from March 17, and the other is the March 22 video just prior to the glass table video.
http://peswiki.com/index.php/OS:_MYLOW%27s_Magnetic_Motor_based_on_Howard_Johnson%27s_Design#Latest_Developments
@all
We see very very clearly everything ... for my part, not a shadow of a "string" there.
VIDEO ANALYSIS WILL BE DONE SOON  ;D
Thanks,
LightRider
can someone make a torrent for the other?
EDIT: Mr. hand theory seems more plausible now...
nyctuber
I've done my own video analysis and discovered the mysterious power source behind Mylow's motor.
http://www.youtube.com/watch?v=_0mcGDAs3f8&feature=related
