Flux density altering/No lentz/Low cog generator
Started by SkyWatcher123, May 24, 2009, 03:12:43 PM
SkyWatcher123
Hi folks, this thread is based on a simple generator principle that im sure others have already discovered, however after tests with a simple design i built it seems to work rather well and has very little cogging drag. I originally built it to test flux gate generator principles where a piece of metal or bolt in this case passes between a stationary coil-core and a stationary permanent magnet to generate voltage/current, however what I have found is that if the magnet is placed at the back or other end of coil-core the generated voltage is almost the same and the cogging drops to a very low level. So whats happening I assume is that as the bolt or iron, etc. passes the stationary coil-core with permanent magnet placed at back side of core, the neutral or bloch wall of the permanent magnets field is shifted more towards the rotor gap or just simply reduces the flux density in the coil-core and then expands again which emulates the expanding and collapsing magnetic field required for induction and with very low drag and no lentz drag either because only steel is rotating. If anyone else has experimented with anything similar or has any thoughts please share them, thanks. Here is a cad pic of the simple layout.
petersone
Hi Skywatch123
I have tried similar setups,and found,along with others,that the Lenz effect is the same as any other genny,there is no relative movement between coil and mag. but the iron becomes a temperally a mag.so no difference.But good luck.
peter
SkyWatcher123
Hi Peter, thanks for reply. Not sure exactly what you built and tested, maybe if you described it in more detail your words would have more meaning, however i know for a fact this design and the flux gate completion designs cause no lentz drag because i have built both, so whatever it is you tested must not have have been the same or you overlooked something in testing. Also what your saying sounds plausible however understand that there is only one source of magnetic field and that is on the stator similar to Peter Lindemanns no back emf motors, the passive rotor steel does not cause counter emf or in this case lentz drag and even if as you say the rotor steel piece becomes magnetized and causes lentz it would have to saturate the steel, if not saturated it would tend to be attracted negating lentz. And since my results prove there is no lentz drag, theories only go so far in reality. Hope this helps to make more sense of things and you might want to do some more experiments.
peace love light
petersone
Hi Sky
I would be very interested to know how it is possible,if a north pole,be it mag. or iron,approaches a coil,the coil will produce a north pole,if you have found a way round it,please tell,I think the Elkin Brown genny is a similar idea,but it was shown to have the usual Lenz probs.You can reduce the Lenz prob.but proportionally the juice!!
peter
SkyWatcher123
Hi Peter, i just did tell my thoughts on the generators and it seems you would rather evade the points i made derived from  experimental evidence, if you would like to have a real conversation I'm here.
peace love light
