Flux density altering/No lentz/Low cog generator
Started by SkyWatcher123, May 24, 2009, 03:12:43 PM
petersone
Hi Sky
Sounds good,but remember you are drawing very little amps with leds,what is it like when the coils are shorted?
peter
Harmonic33
Skywatcher123.
Many if us are interested i'm sure in knowing more about your current rig ie: how many coils / type of coils / inputs / output @ rpms of......... and any other info your willing to share......
Keep up the great work.
Pete. thanx for your input for clarity sake. (As always  ;))
Dan.
SkyWatcher123
Hi folks, thanks for the replies and interest.
Hi Peter, Of course yes thats not much of a load but I had already tested with shorted coils and still no input increase just failed to mention it yet until someone was interested enough.
Hi Harmonic, right now I'm testing only with the 2 coils as shown in the cad pic posted with 16 rotor bolts. the coil cores have the same size steel bolts as rotor and the 2 stator coils use 24 awg wire, each coil is about 6 ohms, and there is a stack of neo's at the back of each coil-core of 1" dia. X 1/2", when coils are wired in parallel max shorted amps are 100 milliamps, open circuit voltage in parallel spinning by hand is 2.5volts, when using a drive motor at 12v at about 800 rpm with about 1.8 amp input, keep in mind freewheeling without magnets attached is only 10-20 millamps below that input which means it has low drag, the volts are just over 5 volts at around 800 rpm. What is really interesting to me so far beside the no lentz drag is that the max amps ramp up at very very low rpms compared to any generator I've ever built or know of and I think it is because there is not a second source of moving magnetic field on the rotor to interfere with the coils generation, akin to no counter emf reluctance motors.
hope that helps some, any more comments or questions are welcome. Understand also right now I'm trying different things to maximize output then later it can be scaled with many more coil-cores for more output.
peace love light
SkyWatcher123
petersone
Hi Sky
Nice simple,straight forward setup,been trying to compute your numbers,not my strong point,to say the least,but I don't think there are enough yet,but I'm sure you will give them in the fullness of time.Look forward to the next episode.
peter
