got over the sticky spot
Started by ScottClarke, February 18, 2006, 09:43:54 PM
ScottClarke
I think you guys probably need to get to grips with the fact I don't get any glee from showing off my creations. No-one has seen my big lifters for eg - I don't have any urge to big-up myself.
Same goes here - I do stuff for personal achievement, nothing more. I know you guys have played with smots, this wheel started life as a smot ramp 3 weeks ago - I went to sleep and decided to put the ball on a wheel - nothing more. The initial results on the wheel looked very promising so I went to work developing it - found this forum via Stefans old yahoo group (a member for years) and decided to post the first wheel vid. Hey, I found it interesting I thought you would too!
I really don't think posting the video I had would really achieve anything - I could easily have a brushless esc under the wood powering the thing. See - I have seen the fakes - I've heard the story - I know full well I could be faking it - as it is.
Tell you what - pretend all I've done is posted the video's. Compare it to SMOT - that would be a good start - it IS a 2 ramp smot.
While you think about that you might like to tinker with some SS balls whilst I prepare a version which discloses fully everything about the unit.
Some points.
The stator neo's are on flexible mounts - they move and follow the ball like little fingers - THINK about that and the balls relationship to it's own neo - flux gradients and all.
The rotor must have mass for it to get over the low power zones without stopping - just like a 4-stroker.
Scott
Omnibus
Scott, the most important thing is to take care of yourself. You don?t need to feel under pressure and to fall sick. So far you?ve done a great job and, as I said, I admire you greatly even for what you?ve done so far. Just relax.
FreeEnergy
i can't wait any longer! lol
scott  ???
i have some neos here but they are too big and too strong to work with  :-\ and i don't have the tools.
*will need to buy some smaller ones
Duranza
Hey Scott.. Where have you gone.. I have been trying to replicate this and i just give up.. It is just not working. Well i hope you are still doing ok, and hope to hear from you soon.
The only way to Validate is to Replicate!
hartiberlin
As Scott is pretty busy rebuilding the motor ,
I am posting his last 3 emails to me:
Stefan - I chipped away at the magnet to get the shape.
Retreating magnets - on my design that magnet which is moving away from the
stator in the nill flux zone.
The stator magnets are free to move around +/-2mm u/d/l/r
----- Original Message -----
To: "SC" <scottclarke@ntlworld.com>
Sent: Wednesday, February 22, 2006 2:10 AM
Subject: Re: Motor...
> From: "SC" <scottclarke@ntlworld.com>
> To: "Stefan Hartmann" <hartiberlin@gmx.de>
> Sent: Wednesday, February 22, 2006 2:50 AM
> Subject: Re: Motor rpm?
>> Stefan,
>> Yes you do need the triangle projection toward the ball. It will almost
>> run
>> without but it does form the 'gate' so without it - no way it will run.
>> Yep, a neo on each ball in exactly the right spot does it.
> I see.
> Did you brush  off a magnet?s corner  or is this just a triangular iron
> core
> attached to a normal magnet ?`
>> Using power to overcome the stick - I believe a Japanese company have
>> such a
>> motor - the power nullifies the magnets force - it does not reverse it.
>> It
>> seems to me this alone is a way to excess energy - yet vastly more
>> complicated than some neo's on balls:)
> Yes, their design has costed all in all until now around 1/2 million US$
> with all the trials and errors and high tech measurement system.
> They are building a bigger motor now, which should selfrun
> in about 4 month.
>> Like I have said - inertia is a major
>> factor - so too is field interaction with retreating magnets.
> What do you mean by "retreating magnets" ?
> Do your stator magnets move back and forth ?
> or the rotor magnets ?
>>These I
>> believe to be the reasons for many failures. I know they have prevented
>> me
>> from using 1/8 neo's on a 3.3inch HD platter. In fact I will go as far as
>> to
>> say I believe togther they have been the reason for the many failures of
>> mine over the past 5 years.
>> I'm going to rebuild it on glass.....
