Creating free energy out of COLLAPSING MAGNETIC FIELD
Started by Tito L. Oracion, May 26, 2009, 12:08:16 AM
Paul-R
Quote from: Tito L. Oracion on May 26, 2009, 12:08:16 AM
How would you demonstrate the slight increase  in collapsing magnetic field?
This is about back EMF spikes, isn't it?
Tito L. Oracion
Quote from: innovation_station on June 03, 2009, 07:22:56 AM
chargeing a cap from the colapse of the magnetic feild ...
http://www.youtube.com/watch?v=FVs_7uCbkbQ
from a 12vdc source ..  useing an inductive tuned setup ...  low self inductance and high self inductance  the high selfinductance winding acts as a choke and forces the kick out the primary ......
ist...
with this set up and some efford it can be made run with gain
ps im ALREADY SHOWING GAIN IN SLOW MOTION HERE ....  ;)
i feel that we're discovering the same thing.  ;)  ;D
Asymatrix
Seems like Tommey Reed took this to it's conclusion and found there is no OU to be had.
Tito L. Oracion
Quote from: forest on June 03, 2009, 06:59:07 AM
where?
Re: Lords of the Ring
« Reply #1 on: January 07, 2007, 06:39:15 AM »
I am listing the instructions here to wind and drive a TPU that produces kicks. Guaranteed!
A word of warning: There is a high degree of danger in doing this!
Overunity comes from the collaspe of the magnetic field.
Devices such as lifters, the ECD, the Turbo coil, and this one here all exhibit the same
physical property called the wing edge effect. That is where the Radiant energy flies off.
The rule is: DO NOT TOUCH THE RING! when it is on. You've been warned. I accept no responsibility for your attempts at completing this project. You are at your own risk. If you follow the instructions and end up in a dangerous situation, it is your fault, not mine. I have had my dangerous moment already and it isn't pleasant.
