Thanks to ALL for your help!!
Unable to account for frequency related to Magnet being pulsed by Inductor
Started by duff, May 27, 2009, 02:08:08 PM
duff
Quote from: allcanadian on May 31, 2009, 12:32:32 PM
@Duff
I built and tested the exact same setup you have last year and found the exact same phenomena you describe. It took me a while to find my lab notes on this, about 10 pages, LOL. I produced many variations with multiple coils, multiple magnets etc... .I believe some people here are reading way too much into this, the problem is one of perception, you see a stationary magnet on a stationary coil and have concluded there are oscillations coming from somewhere else. I found the secondary oscillations are from loose coil windings,when the coil windings were varnished the oscillations disappear. I am not saying this effect does not show promise I am just saying I found "where" the oscillations were coming from, it is basically standard induction but the motion is on a very small scale which is misleading. Try "tapping" the magnet on the hard plastic of the wire spool with your scope on the leads and you will see what I mean or hit the table the coil is on. It's pretty cool actually, like a massive microphone or speaker coil.
AC
AC,
Thanks for the info.
I'm running the osc & driver on DC now and the 959 freq is still there.
I can hold the magnet in my hand above the winding (off the spool) and hear a tone coming from the magnet (domains moving i suppose) and if put my ear to the winding there does seem to be sound there -  it's difficult to tell for sure.
The coil windings in my case are not loose for it was tightly wound and the wire very stiff (400' #10 magwire) so I doubt the wire is moving but he domains in the wire  in motion.
I did try hitting the coil with the handle of a nut driver and noted no microphonics nor difference in beat tone though it may have been so subtle my hearing couldn't detect it.
Question: When you tried multiple windings did the beat frequency occur above & below the 959Hz in every case??
If the center freq was constant, then I'm wondering why the same frequency is common with windings of different lengths & physical characteristics. I suppose it could be related to the diamagnetic characteristics of copper.
-Duff
duff
I have now determined that the beat tone is coming solely from the inductor.
When I previously placed my head outside the coil I heard nothing.
Tonight I placed my head on top of the plastic spool, over the center, with the magnet removed.
The spool of course has a cylinder center with holes in it ends and sound there is amplified.
What I heard there was two tones and a wavering beat note.
When the magnet is placed on top of the spool it amplifies the affect.
-Duff
BEP
Quote from: duff on June 02, 2009, 02:12:35 AM
-Duff
Amplifies?
Weren't there many folks here that determined a magnet had no real effect upon a coil?
Regardless, Nice work @duff.
wattsup
@duff
This is my one and only youtube made way back. May help explain.
http://www.youtube.com/watch?v=XXgL4Wf8zrQ&feature=channel_page
Also, I have pulsed many toroidal transformers with the same sound. Basically a some loose wires being vibrated making like a transducer action or more like a speaker coil.
Added.
When I had the sounds on my toroidal transformer, I took a flexible tube, put one end in my ear and used the other end as a sound prode to identify exactly from which part of the toroid it came from. In my case it was from the wire just at the center air core.
Quote from: duff on May 27, 2009, 06:55:33 PM
Yes, I am sure the magnet is singing.
It sings sitting on the top of the plastic spool and it also sings if I put it on a piece of paper and raise it above the spool (up to six inches). The beating freq ceases at 959Hz.
I don't have a piezo handy - will check radio shack...
The question is exactly which  ambient fields is it interacting with and how do I prove it.
Here's a pic for better clarity.
-Duff
Edit: It also sings while holding it in my hand close to the top of the inductor though it is very faint.
Uh-huh.
