Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
i_ron
Quote from: CRANKYpants on June 14, 2009, 04:07:28 PM
I_RON IN CHARGE - JUDGE - AND JURY - THIS MUST BE THE NEW-I_RON-ORDER I HAVE BEEN HEARING ABOUT COMING FROM THE WEST COAST - I AM SKIPPING TOWN WHEN YOU GET TO BE THE EXECUTIONER THOUGH.
HERE IS THE ORIGINAL VIDEO:
http://www.youtube.com/watch?v=jpIdu1lWVW0
THE ROYAL WE ARE NOW USING REAL TOROID TRANSFORMERS WITH A PAIR OF 22 GAUGE HV COILS ON THEM AND 2 - 18 POLE ROTORS INSTEAD OF WHAT WAS SHOWN IN THE VIDEO.
VERY SIMILAR TO STEVE'S SATURATING CORE VIDEO BUT WITH HV COILS.
HAIL TO THE TEET!
T
Thanks for the link, but the one I was trying to refer to was the latest video with the 11? cores mounted on the toroid ring.
Hoax was just a word that came to mind but I see I used the word.
"A hoax is a deliberate attempt to dupe, deceive or trick an audience into believing, or accepting, that something is real, when the hoaxster knows it is not;"
A better word would have been "illusion"
This is the word I shall use in future when I refer to the three legged E core, OK?
Ron
slapper
Took a small break from my Sunday afternoon of mundane design work and catching up on to good ole conspiracy theory sites.
The pickup coil used is from a cheap Taiwan ringer assembly shown in the first image. The DC coil resistance is quite high for this application at 5K ohms.
The second image shows the Hall Sensor probe lined up with the mounted coil. The third image shows the overall rotor assembly (at great risk of humility).
I then spun the rotor by hand and took a few snap shots with the scope with various loads across the coil.
Image 4: Open Coil
Image 5: 4.7K
Image 6: 1.2K
Image 7: 330 Ohm
Image 8: 56 Ohm
Image 9: 12 Ohm
Red: Sensor
Blue: Coil
The magnets are laid down SN|NS
Didn't see much shift between the 1.2K Ohm load to the 12 Ohm load but I haven't run the numbers.
Take care.
nap
we are not alone :)
CRANKYpants
Quote from: i_ron on June 14, 2009, 04:00:36 PM
The HV coil is a convention coil, only with more turns, a higher inductance, and greater resistance. It obeys the same rules.
Ron
THIS IS WHERE I GET BOOTED OFF THE ISLAND BECAUSE YOU MUST BE IN "CHARGE" OF THE EMPTY BOX - EITHER THAT OR I HAVE FALLEN INTO A WORMHOLE AND GONE BACK IN TIME.
A HV BI-FILAR SERIES WOUND COIL HAS INCREASED CAPACITANCE AND MOST LIKELY DECREASED INDUCTANCE - AND IT CERTAINLY DOES NOT OBEY THE SAME RULES.
An early example of the bifilar coil can be seen in Nikola Tesla's United States patent 512,340 of 1894. Tesla explains that in some applications (which he does not specify) the self-inductance of a conventional coil is undesired and has to be neutralised by adding external capacitors. The bifilar coil in this configuration has increased self-capacitance, thereby saving the cost of the capacitors. It is notable that this is not the kind of bifilar winding used in non-inductive wirewound resistors where the windings are wired anti-series to null out self-inductance.
ONE THING IS FOR SURE AT 500 RPM THE COILS IN OUR LATEST VIDEO DECELRATE THE ROTOR - I WILL POST A VIDEO FOR YOU IN A COUPLE OF DAYS - BUT ABOVE 1000 RPM THEY DO NOT OBEY THE SAME RULES.
AND YES RULE #1 ABOUT INVENTING MEANS DON'T LISTEN TO ME EITHER.
UNLESS YOU SEE IT FOR YOURSELF.
T
CRANKYpants
Quote from: i_ron on June 14, 2009, 04:19:49 PM
Ron
FAIR ENOUGH AND I SHALL REFER TO YOUR COMPREHENSION WITH THE WORD "DILLUSION":
1 c : the deliberate posturing with apparent conviction that a perception or idea that is true and which appears to be true is a mirage, or the reverse, that a perception or idea that is false and is known to be false is true, until one completely succeeds in fooling oneself.
4: a stop without a farmhouse near between the woods and frozen lake the darkest evening of the year.
6 : hallucination that one can spell.
T
i_ron
Quote from: CRANKYpants on June 14, 2009, 02:45:41 PM
HERE IS WHAT PEOPLE SHOULD DO TO REPLICATE THE THANE HEINS PEREPITEIA PROPERLY.
2) DON'T LISTEN TO HOPTOAD.
T
Perhaps somebody should?
http://www.totallyamped.net/adams/page11.html
Cheers
Ron
