Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
0 Members and 18 Guests are viewing this topic.
minde4000
Thank you Thane for all this additional info.  I tought we are here to replicate his work and I mean but with all this shit coming out from people who do not posses any setup I probably would not waste my time also. I was glad T was back so we could get an advice when needed...
  Personally I will go with this forward and until someone or myself proves otherwise by building a descent setup. What a drama.
Minde
Asymatrix
So, is this OU, or just a highly efficient electric motor?
hoptoad
Quote from: CRANKYpants on June 14, 2009, 09:03:17 PM
HOPTOAD AND STEVE EXPERIENCED THE SAME PHENOMENON - ONLY STEVE WAS SMART ENOUGH TO CHANGE HIS SOLID IRON CORES TO LAMINATIONS AND THEN WATCHED THE
"ACCELERATION" DISAPPEAR.
HOPTOAD USED HOLLOWED OUT IRON CORES WHICH EVENTUALLY SATURATED WITH LOAD.
SATURATED CORES REDUCE EDDY CURRENT LOSSES AND EASES MOTOR WORKLOAD BUT AS STEVE DISCOVERED IT IS NOT SUSTAINABLE.
T
Actually, just like Thane's, my research started with solid iron cores. I succeeded in getting the apparent "acceleration" effect, but the electrical output was poor.
Then I switched to laminated cores and achieved a greater electrical output and still succeeded in getting apparent "acceleration" to occur.
But the output results were even better when I switched from laminates to hollow alloy cores, and the "acceleration" effect still occurred.
Cheers
baroutologos
Hi at all,
Gentlemen, i like to think we are on the same side here. Afterall we are all in pursue of electrical OU. Anyway..
@ Mr Thane.
You said that currently you use biffilar (parallel wound) series connected coils. Indeed this setup boosts coil's capacitance to a number of magnitude degrees. (thousands if not millions, depends on voltage)
But, my experience with it yielded not any special result. On the contrary parallel wound, parallel connected i saw some very encouraging ones that i posted earlier.
SInce you have been thoroughly experimenting with this setup can you please enlighten the situation? (parallel wound coils - series connected)
I notice you mentioned that magnet strenth is one of the factors that HV coils are not working?
My setup has 1'' diameter neos double stacked. Field strenth is quite strong in the face. I use a typical 8-10mm gap (magnet-coil core) Maybe is it too little?
Note that my rotor (6 magnets all N out) has the same frequency capabilities/rpm as an 12 pole magnet rotor of alternating polarity. (even though power generation is half)
Suggestions are always welcomed
Another idea of Mr T that i was thinking too past weekend. How about one skillfull enough to get an Permanent Magnet Alternator and rewire it (what a struggle!) according Perepiteia's principles. (all laminations, all coils "grounded"/ magnetic flux closed looped etc) This will be the utmost "thing".
Regards,
Baroutologos
ps: Peace brothers  ;D
minde4000
@HT
Nice to hear you get acceleration. Would you mind to post a picture of your setup?
Minde
