Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
CRANKYpants
Quote from: baroutologos on June 25, 2009, 05:25:44 AM
Nice MINDE!
well done.
It's also time to proceed experimenting with coil arrangements, gauges, parallel windings etc etc. Its good to see the rotor of yours resembling Mr T's rotor from the very beggining. Mine as you know was not since i tend to proceed from elementary to more complex designs by seeing and learning in the process (it's a curse actually! Too much cost)
I saw you are in search for laminations + coils.Those are pain in the neck :) Mine are ordered and coming from the far America Continent :P) . After some thought those are going to be of two kinds for experimenting.
I am really curious to see Mr T's effect on those different coil's geometries.
Regards,
Baroutologos
THIS IS A GREAT CONTRIBUTION - THANKS B.A.R.T.S!  ;)
IF YOU HAVE 2 COILS THAT ARE THE SAME - MAY I SUGGEST YO LEAVE ONE AS IS, w/ 16 GAUGE WIRE ON IT (CONVENTIONAL HC COIL) AND REWIRE ANOTHER ONE WITH 26 GAUGE BIFILAR WINDINGS (REGEN HV COIL)?
ALSO I WOULD SUGGEST YOU TRY TO GET I_RON TO MAKE YOU A ROTOR - THERE ARE NONE BETTER! AND HE MAY BE WILLING TO DO IT FOR YOU IF YOU TELL HIM THAT YOU ARE ONLY INTERESTED IN GETTING DATA FOR YOUR NEW:
"THANE-HEINS-IS-A-SHYSTER-AHOLE-AND-THE-PEREPITEIA-IS-A-MUNDANE-HOAX-PIECE-OF-CRAP" THREAD
T
alan
If you have a HV [bifi?]coil standing on the table, and ya drop a magnet on the top side, does it keep bouncing because of the delayed repelling bemf? the characteristics of the coil are chosen in relationship with gravity to get the desired max impedance. the magnet is dropped in a long hollow tube or something.
with a load connected suchas in the perepiteia setup, like a mot and or lampbulbs, no caps to form a tank.
Nali2001
It might bounce a little if you make the coil into a tank circuit. Where the induced power can bounce back and forth between cap and coil. But a coil alone would very hard since they probably have only capacitance in the nF range. And that also means that they can not respond to such low freq inductions.
i_ron
Quote"THANE-HEINS-IS-A-SHYSTER-AHOLE-AND-THE-PEREPITEIA-IS-A-MUNDANE-HOAX-PIECE-OF-CRAP" THREAD
Couldn't have said it better myself!
As we both know this is your list, it was only mine up until your first post.
But it was fun to pull your string and watch the show....
Dboss, OUman, Polar Breeze, Natan, have all said it much better than I ever did. What I did was quietly and simply point out, with actual evidence, where your theories and models where at odds with the truth. Some people already knew, others will find out for themselves. Not once have you come back with any evidence to the contrary that what I have said is wrong, so I will let my work speak for itself.
Ron
LarryC
@all,
Picture of setup with neo catcher. Had to do it to test inside, 110 heat index outside. Africa hot.
Thane, my original coil (120 ohm) worked about the same on the Ryobi as on the old higher HP cheap Fred motor. However, the Ryobi runs a couple of hundred rpm's higher at the same input voltage.
I still have a large spool of 28 gauge wire, so next step will be winding a bi-filar coil using that and check the difference.
Thane, exactly why does your rpm's have to be much higher now for acceleration? Asking, because I'm still using the old rotor and would have to upgrade to handle that speed.
Regards, Larry
