Thanks to ALL for your help!!
Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
baroutologos
As an ol' pyrrotechnics saying goes...
"they are old pyros, and they are bold pyros,
but they aren't too many old, bold pyros.."
Regards,
Baroutologos
* pyros = pyrotechnician
CRANKYpants
The Bi-Toroid Transformer is designed to convert Reactive Power to Real Power.
This is accomplished by introducing a secondary coil and alternate flux path route â€" keeping the primary coil isolated from the secondary induced BEMF magnetic fluxes
The extra energy required to produce a transformer that operates at over 100% efficiency comes from the fact that the two secondary coils self regulate their own flux required to maintain the voltage across the load and the primary coil remains unaffected by secondary load.
IF ANYONE WANTS THE COMPLETE REPORT - SEND ME A REQUEST @ thane_heins@yahoo.ca
T
CRANKYpants
IN AN EFFORT TO REDUCE METER ERROR IN THE BI-TOROID DATA...
TEST DATA #6  July 16th, 2009
Load Voltage = 3 volts
Load Resistance = 27.5 ohms
Calculated Load Current = 0.109 amps
Metered Load Current = 0.111 amps
Meter Error = 1.8%
T
baroutologos
I had some minor experiments with my top quality core and magnetic circuits.
I had a question regarding the picture below. I found out (ferrite magnets were employed for the experiment) that totally closing the magnetic flux, i got some x3 or x4 more flux (i measured strenth of part as a tedency to attach each other) in closed circuit. case B
So, all of you who have steel rotors, you already have the one part of magnetic circuit closed.
My alluminum rotor, leaves in open air magnet's one surface, so closing the loop on the other side, will give not even close the flux you people get..
pffffffffff.....
Regards,
Baroutologos
CRANKYpants
Quote from: baroutologos on July 18, 2009, 04:31:08 PM
pffffffffff.....
Regards,
Baroutologos
THANKS FOR THE INFO THERE BART - NOW YOU NEED TO BUILD A NEW STEEL ROTOR SO YOU CAN GO FLUX YOUSELF AS WELL LIKE US.
T
