Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
lespaul109
have you watched all of his vids on youtube? they explain much about the 2 coils
this is my favorite:
http://www.youtube.com/watch?v=L3JVjbXOssQ
GREENPOWA9312
Yes i did, but they still  left me a bit currious, ive got exhausting answer from THE MAN himself hooray!
Its much cheaper than i was afraid of. Unbeliveable!
Cheers!! so happy..
lespaul109
My experience
if i remmber correctly, I was only able to get out about 6-7 watts from this coil. I wrote thane and he told me to build another coil with 22AWG wire for higher output. I calculated the resistance/foot of his better coil, and I would need about 8 pounds, that is about $80 from my supplier which is a local electric motor repair shop. So I would suggest building one of his type if you are starting to replicate, learn from my design and save money.
Important info! Please read.
From what I have noticed, there is "NO" counter force made by taking electricity from the coil. There is however a counter force caused by the magnetic drag of the steel/iron core(large bolt in my case) this is proven because in my tests the motor does draw more current when the core is in front of the rotor with the coil "DISCONNECTED" than when it is not near the rotor at all. When the core is close and the coil is connected(producing usable electricity) the rotor does speed up(accelerate). So literally the drag of the core is reduced somehow by the field of the coil being connected. This effect increases with more energy being taken from the coil. In summary, if I make the larger coil(7-8lbs 22AWg 60ohms) which extracts more electricity, while using the same core(the only source of drag) it should reduce the core drag more and produce more output in watts.
sorry for the lengthy explaination, it's a lot to comprehend.
jake
LarryC
lespaul109
