Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
minde4000
Quote from: mrclean on May 03, 2011, 04:39:13 PM
Hello all :) new to this forum :)
i have built a couple radiant replicas, but the other day i heard of Thane Heins's magnet motor & in a couple days had one thrown together.
Here's a couple links to my two Perepiteia replication vids
Regenerative Acceleration Replication Part 1
http://www.facebook.com/profile.php?id=1079243991#!/video/video.php?v=1872602329661
Part 2
http://www.facebook.com/profile.php?id=1079243991#!/video/video.php?v=1879487341782&comments
let me know what you think :)
Been there done it. Also I had a descent setup. You can find under my uploads.
You see shorted out coil acts like a magnetic flux capacitor so its like a spring - barely loads up a drive motor - almost no voltage almost no waste of heat.
Open coil works more or less like electric flux capacitor. Especially when I had my bifilars - at higher rpm voltage risises so high that its starts "leaking" between bifilar windings in form of ion wind or plasma formation. Bifilar and high voltage dont go together because there is a maximum voltage difference between adjacent turns of magnet wire. Should not exceed 1000 VAC ptp when working with bifilars. In any case many turn containing bifilar coil will start to slow your driving motor down after you reach higher frequency. Once you short it out it does unload a driver and rpm increase.
  Personally I have not found anything "special" about this Perpetia scam.
Minde
Also AC induction motor is super deceiving in this case. DC motor will not exibit "accelerations" or "decelerations" in such a magnitude.
ramset
Mrclean
Btw,Welcome to the Forum!
We Need all the experimenters we can get around here!
Please see also Here!
http://www.overunity.com/index.php?topic=10518.msg284082#new
The above is a "Take Off" on Thanes work ,Thane is helping the inventer {Mavendex}with Patents,But Mavendex is Open Sourcing as well as assisting replicators!
1 "WATT" In 12 WATTS Out  And rising..................
Chet
Thanks Grandma
baroutologos
I more or less agree with Minde.
I have extensively been experimenting with Peripeteia setup. No free energy there. The only peculiar thing is that, a solid iron core next to spinning magnets posses a huge drag, even having not the coil loaded.
On the contrary, if it is shorted, yet, the impedance - resistance- frequency, allows minimum energy dissipation to coil's windings (or the relation of current and resistance), that circulating current alleviates to a great part that initial drag and whole system seems accelerating.
Lately for the needs of another experiment, i modified the Peripeteia rotor setup to spin past odd / even coils config, having minimum drag and coil's core to be made out of ferrite material. In other words, no losses.
I cannot achieve the Perepiteia effect there no matter what.
For me that thing, its explained and not ou.
mrclean
& i appreciate the welcome, i agree we need more ppl :)
