Thanks to ALL for your help!!
Zero Point energy
Started by Dave45, June 01, 2009, 11:14:44 PM
newbie123
Quote from: IotaYodi on June 02, 2009, 11:12:08 PM
If you mean a dead stop being Supercooled is the only thing I know of.
Does super cooling even stop atomic electrons?  I thought they continued to vibrate  and their 'vibrational energy'  at 0k is considered ZPE.
Until you can measure it, arguing about something can be many things.. But science is not one of them.
Tito L. Oracion
Quote from: Dave45 on June 01, 2009, 11:14:44 PM
How does a generator make electricity, I know you pass a magnet over copper wire but where is the energy coming from, are we already tapping into the either does the magnet and the copper wire cause a sink, if it can be done this way there should be other ways a way without movement or maybe vibrations.
The magnetic field, number of turns of the coil, the core and the speed of switching on and of of the magnetic field,  they all contributes to the production of electricity, and if there is a secondary coil then electricity is transfered because when switch is turn off then tension is build up and electrons are traped   so when there is a close then electrons start to move to nutralise the tension and the trap electron and seek for balance right ?    8)
God bless  ;D
otits
Tito L. Oracion
Quote from: Dave45 on June 02, 2009, 10:28:38 PM
what material stops electrons?
what material is the best conductor of electrons?
according to the info i've got well, rubber and plastic will stop the electron from flowing.
silver and gold is the best but because of its price then copper and aluminum is the alternative ok  ;)
god bless  ;D
otits
Dave45
Quote from: Tito L. Oracion on June 03, 2009, 04:30:44 AM
If rubber will stop electrons then a magnet must emit something other than electrons because it sticks to metal through rubber.
IotaYodi
Quoteaccording to the info i've got well, rubber and plastic will stop the electron from flowing.
As far as conductivity gold is less than 100%.
Rubber and plastic like any insulator will not conduct electrons very well but at higher voltages they can build up and travel across them. Photons of sun light will eject an electron from metal. Its not because the electron was just sitting on top but was part of the metal itself.
http://www.youtube.com/watch?v=FWOst4VwwEU&feature=player_embedded
What I know I know!
Its what I don't know that's a problem!
