4 PISTON MOTOR THAT JUST MIGHT WORK. YOUR THOUGHTS PLEASE...
Started by JohnPK, June 08, 2009, 08:03:34 AM
Tommey Reed
Imaginary idea waste time and money, no power can be made for something that can't run. As for my rotary engine, Its is new technology that's why I have a patent on it, and also the ratchet engine. These engines run on any type of fuels and even air pressure.
If you know anything its all about make energy not a clock that ticks.....
That's why I said before,its best to but a solar panel then playing around magnet that won't produce any real power.
Its a joke to see others trying to make a motor that spins with no true energy being , it's nothing more then playing with magnet fields that is doing nothing with real power.
Energy is the problem, not a rotating machine that could not put out any real energy.
You would have been better off to build a better windmill, then play with magnets that won't produce nothing!
Sorry to tell you the facts >:(
Tom... 8)
lumen
@Tommey
You should take your genius to the thread "Maxwell's Demon" and use your ability to design a efficient heat engine to run on the temperature difference of hot and cold water!
Then you could see how your new motor could produce energy off nothing but gravity!
Wait, gravity is another field that cannot produce energy.
Conservative fields do not produce energy but they can organize or reverse entropy to produce areas of increased energy without creating energy.
But then, if the energy was organized and usable, is this not real energy because it was used once already?
Tommey Reed
Wont work, using Gas law and Charles Law you wont produce enough pressure from expanding gas to do real work. That's why there is nuclear power in the first place...
:o
Tom
lumen
Wow, I thought the internal combustion engine was an expanding gas engine, and steam engines really did not work!
Well I guess I have been fooled before but this comes as a real shock! I better throw away all them old useless books I have showing that junk actually working.
Tommey Reed
If you want to be a ass hole then ok, gasoline is the fuel to run  heat engine, and other fuel are used to heat up water into steam to be used for steam turbins.
My point is you think a motor run on OU and can power your house.
Solar comes from the Sun, and yet you think magnet will power the world. Throw  those books out that made you believe that magnet will run forever, and power your homes to get free energy! ;)
