4 PISTON MOTOR THAT JUST MIGHT WORK. YOUR THOUGHTS PLEASE...
Started by JohnPK, June 08, 2009, 08:03:34 AM
Tommey Reed
As simple as a wheel turns, no magnet motor could ever have enough extra power to do any real work. More mechanical parts add more friction and drag on a mechanical system. less part for a so called magnet motor the a better chance that you will have a wheel that spins, but no power can be draw of of it.
Tommey Reed
eavogels,
It wont work, too much drag with gears and magnet won't do what you think it will. You would be better off to work on a single wheel then add too many parts that will drag this to a point of no return.
Think simple! >:(
JohnPK
Wow! Is it safe for me to come back to my thread?
Just for kicks, let me put this into perspective, so far I have a $50.00 investment into this project. except for my time, that is all. I was having a good time with this invention, and I spent a little dough to keep the magnet guys in business. My wife knows where I am, I'm not in the bar, my dog is not starving because I spent all her dog food money on magnets. Live is good.
And it's kind of cool getting a troll on my first thread.
But can we get back to thinking positive without killing a thread?
Lumen, I might be able to put both shielding devices on one set up. You believe that I would be better off starting with out the half moon shield and just start with something similar to what you've drawn? John
lumen
The half moon or shield between the repelling faces will generate a pull that I believe takes the same as any energy that could be gained by the repelling faces. All the testing I have done using this configuration indicates this. I use a modified digital fish scale to get very accurate readings.
I have my own CNC machines and usually make my own gears from 1/4" lexan. I can usually build a device over a weekend but sometimes it takes a day to draw it up in 3d.
I have a plan for a device that should confirm this concept with only two moving parts and this should provide some additional data.
If you have your half moon shield made already, you could try it out so you might have something to compare the results against.
ramset
Thanks Grandma
