Colloidal Silver Water
Started by zenmountain, June 13, 2009, 01:10:42 PM
itanimuLLi
Quote from: Goat on June 15, 2009, 10:55:26 PM
Hello everyone :)
After years of looking into and finally using CS I found that there was a lot of information that was contradictory so it was hard to make sense of who's right and who's wrong about; uses, doses, types of silver ie: Silver solutions with silver salts versus Pure Silver etc...To make a long story short, my decision was based on the following information from an article called The Safety of Using Silver Solutions and the Risk of Argyria
Keith Moeller, American Biotech Labs, January 15th, 2008
At:  http://www.guardian-silver-health-supplements.com/learning/article/keith-moeller-safety-of-silver-solutions/
This article seems to cover all grounds regarding internal consumptions and limits as well as types, turns out that the silver salts are a bad thing so I would be careful about purchasing something I didn't make.
As with all things though, making your own CS takes some due diligence as well as consuming it, be careful!
Note:  After looking at several plans to build my own I decided on the Scada Research RSG-2 at the time and make my own CS since then with no regrets so far because a little goes a long way for me :)
Regards,
Paul
Hi Goat,
Simple question wat is your way of making CS I am very interested.
thx.
zenmountain
Hi Paul and the rest,
That was some good information that you submitted. I myself first purchased a Sota Instruments pulsar/cs unit which appears to be similar to the systems you mentioned over at Scada Research where it looks like they have some interesting machines. Thanks for the link.
Those that are interested in similar technology can have a look over at http://www.sotainstruments.com/  where they have the full line of stuff for Bob Beck's complete protocol.
Speaking of contradictory information the guys over here you mentioned at guardian-silver-health-supplements.com are so biased against ionic/colloidal silver that it is nearly comical. I haven't any doubt that their own product is good or perhaps even better but without mentioning details here their information about the competing colloidal/ionic solutions is really misleading. Goes to show again that it is indeed difficult to get unbiased information.
There are very reputable companies that have been providing quality, safe and effective colloidal(ionic) silver water to the public for years. It is worth the money and effort spent on ensuring one ingests only quality made silver water whether you've made it yourself or bought it from a reputable supplier.
I have sold a nice 10-20ppm colloidal silver inexpensively to 100s of people over the years. It has benefited nearly everyone and not a single one had any adverse effects. There are no records of people dying from the intake of silver water in any form even poorly made ones and yet 100,000 die annually in the USA from antibiotics that are 'properly' prescribed. Silver is the only metal that you cannot get 'heavy metal poisoning' from.
Those that want to make their own batches at home should educate themselves properly and ensure that they only ingest colloidal or ionic silver that is made with pure water only and the purest silver available. Creating only the smallest particles is essential for both effectiveness and safety.
All in all this wonderful material has a lot of upside and very little risk. Everyone should learn about it and have it on hand in their own homes.
cheers,
Goat
Quote from: itanimuLLi on June 16, 2009, 04:27:18 AM
Hi Goat,
thx.
My preferred method is:
1.  Use water that is pure or close to it (Distilled water with no minerals and salts or better) I use a clean glass container (Glass mug in my case) that is clean and tripled rinsed using the distilled water to clean it out.
2.  See picture below, using this device on the 1mA which is the CS (Colloidal Silver) mode set to "Const" which is the constant current at 1mA mode I run it for 20 minutes at 20 Degrees Fahrenheit and then put in a dark glass triple rinsed glass wine bottle stored in a dark cool temperature location to use later on.
3. In my experience I've had no luck at all using the 20mA setting "Limit" under the CS setting, I ended up with a batch of dark stuff accumulating around the silver rods but the 1 mA setting "Const" provides a clear batch every time for me so far.
4.  I only use the CS sparingly so far both internally and externally for different health reasons to see if it makes a difference and so far I think it does more good than harm, so this far so good!
Keep in mind that the above statements are only my experience this far, others may say different, but considering that I've not caught the latest cold everyone else had around me I think it's relatively safe to use and may have beneficial effects.
Considering that most of the current anti-antibiotic's are selective and no longer effective I'm willing to use it if it has an advantage.
Regards,
Paul
Goat
Quote from: zenmountain on June 16, 2009, 08:06:46 AM
cheers,
@ zenmountain
I completely agree with you, especially the:
"Those that want to make their own batches at home should educate themselves properly and ensure that they only ingest colloidal or ionic silver that is made with pure water only and the purest silver available. Creating only the smallest particles is essential for both effectiveness and safety."
As I mentioned before, educate yourself, then make your own decisions,  I have and it's working for me, if you don't feel safe making it yourself then at the very least buy it and try it as only an external treatment to prove that it can do what is claimed, if it works then move on to other tests.
Regards,
Paul
rMuD
My generator is made from a  99.999999% pure silver wire, harmonic case, with a dc adapter and a step up circuit to output 27v  a LED too so you can see how well your conducting thru the water.  Keep the rods clean of oxidation!   Been using it for 15 years with no ill effect.
