Colloidal Silver Water
Started by zenmountain, June 13, 2009, 01:10:42 PM
blueplanet
I personally wish that more research efforts be directed to the role of selenium on argyria:
http://web.archive.org/web/20070220152747/www.silverprotects.com/argyria.html
I do not have enough resources to run a medical trial, but I have done some tests on myself. Up until last month, I had consumed quite a lot of colloidal silver.  My forehead began to change color. This color change might be caused mainly by excessive exposure to sun,  but I wouldn't rule out any possiblity that I might have picked up some negative side-effects of colloidal silver. Since then, I also consumed a few brazil nuts every day in a hope that the selenium in brazil would reverse the situation. To my surprise, I did experience a very noticeable change in my digestive system, and the color of my forehead became normal again in less than a week.
I don't know how to explain this experience in english. I wish that more trials could be run to confirm the findings of Dr. DM Portland.
Mark69
@Blueplanet
What color did forehead turn?  If it was blue, I cant see how the sun would cause that and would have to lean towards the colloidal silver.  How much of it have you been consuming?  How strong is it too?
@Exx,
Thanks for the info.  If I understand the BYU study correctly, the silver water was effective against every one of the bacterias tested.  These things are hard to read.
Mark
blueplanet
Quote from: Mark69 on August 06, 2009, 09:22:46 AM
@Blueplanet
Before I ate brazil nuts, the color of my forehead was very black.
I could not remember exactly how much and how strong the CS which I consumed. All I can say is A LOT. I don't think the amount and the potency are the real cause of the problems in this case.
I have to rely on CS, because I need to survive on well water and CS is unfortunately the only thing that can make the well water drinkable. The CS was made from distilled water, but the well water is just well water. You may assume that some silver salts might have been formed in the mixture of CS and the well water.
Mark69
@Blueplanet
Can't you boil your well water or set up a simple still to purify it at least for drinking?  I think if you ingested too much silver, it would make your skin blueish and that would be all over, not just your forehead, though I am no expert.
Mark
blueplanet
I have done all this. I even use UV-C light to disinfect the well water.
As I said many times before, the problem does not lie in the CS concentration alone. The problem lies in the lack of selenium and vitamin E.
Quote from: Mark69 on August 06, 2009, 01:10:31 PM
@Blueplanet
Mark
