Colloidal Silver Water
Started by zenmountain, June 13, 2009, 01:10:42 PM
oroshay
Hello All,
I started this treatment 3 days ago as part of the Bob Beck Protocol, and I am starting to herx now. So I guess it is starting to work ok.
I had my doubts at first because nothing was felt while treating or any effects felt after treatment, but I think it takes a few days to kick in.
The Coloidal Silver I produce is clear no matter how long I "cook" it for. I use pure sterilized distilled water from my local pharmacy, (I live in the uk) and 99.99% 2mm diameter silver wire from Palmer Metals who specialise in distributing to the jewelery trade. I also use a constant current circuit using the LM344Z at 1mAh and 36 volts for a minimum of 4 hours a batch.
The Bob Beck Protocol uses the fact that micro currents in the blood cause the cells to have electro porosity and hence "open up" to allow the previously ingested Coloidal Silver to enter the cells. My condition is characterized by hidden bacteria in the cells, called cell wall deficient bacteria and it is this bacterias way of avoiding antibiotics etc.
So far, after a doubtful start, I am getting a reaction that indicates that these bacteria are indeed being targeted and that the treatment is working.
I will keep you posted.
Regards, O
oroshay
I just found this amusing piece on the web. Please do not take it seriously or try this at home!
Quote:
You can prove it to yourself easily with this simple scientific experiment.
1. Go to a local subway station.
2. Proceed to lick every handle/seat/floor possible.
3. The next day when you are violently ill, on an empty stomach drink an 8 oz glass of colloidal silver 15 ppm.
4. When you feel better within hours of drinking it, write down how long it took to feel better.
Now for the double blind part, repeat the steps above.
This time DO NOT drink colloidal silver. Write down your recovery time.
Repeat this until you are convinced, or otherwise of it efficacy.
This works with food poisoning too, so instead of a subway post, go raid a dumpster for rotten food.
:D
oroshay
Dr. Roger Altman has tested CS in vivo with very good results.
The paper of Roger Altman study can be found here:
http://silver-colloids.com/Papers/AltmanStudy.PDF
This study is at least 10 years old but should be informative to all interested in CS as a "Second Immune System" for your body.
Regards, O
jacek
Oroshay said:
"The Coloidal Silver I produce is clear no matter how long I "cook" it for. I use pure sterilized distilled water from my local pharmacy, (I live in the uk) and 99.99% 2mm diameter silver wire from Palmer Metals who specialise in distributing to the jewelery trade. I also use a constant current circuit using the LM344Z at 1mAh and 36 volts for a minimum of 4 hours a batch."
I have been using a similar method for about 18 months now and my colloids are always clear too. The process starts at about 35 V DC and then the current limiter circuit gradually drops the voltage to about 22 V DC at the end. Current is limited to about 800 micro Amperes. From beginning to end it takes about 5 to 6 hours for almost 1 gallon of distilled water. Wires polarity is auto-swapped. Someone (this thread?) mentioned they brewed their colloids during new moon so I tried that and it looks like the Tyndall back-scatter effect is barely visible (smaller particle size perhaps?) with respect to the previous times when I made my batches.
The metallic after-taste is still pretty strong.
Happy experimenting everyone  :)
exxcomm0n
Hi all,
Present (money making) projects are keeping me from  doing the tests I described earlier (although the moldy bread is presently getting moldy), but that has not kept me from brewing up 3 batches of CS.
All batches use:
1.) Wal***t (already had it from HHO experimentation) distilled water
2.) 500mL (2 cup) pyrex mixing cup
3.) 3.5-12V @ 600mA multi-device wall adapter
4.) AtlasNova 99.99% 10 gauge wire
The first batch was electrolized for 2 hrs. and used 9V setting with small (under 5 min.) bursts of 12V to just when the Tyndall efect became visible, though I'm not sure of moon phase @ the time. It was stored in a brown glass container pills came in.
The second batch was done @ 12V for 3.5 hrs. with .5 hr. 9V at the end. A much stronger Tyndall effect was seen. It was stored in a brown PLASTIC bottle that used to have Hydrogen Peroxide in it.
The third batch was done at 9V for 12 hrs. with stirring every couple of hours. It is being stored in a glass cobalt blue bottle that used to hold Riesling wine (it was SUCH a trial to empty ;) ).
All batches are clear in color (no yellow).
The 1st batch I'm presently using as it seems a light enough concentration for daily use and does have a slight metallic taste. I take 1 tsp. or tbsp. per day w/ a 550mg American Ginseng capsule (Ginseng's effectiveness I can personally vouch for as I've been taking it for 5 years now on and off and when I take it DOES have "restorative" properties in my case ;) American ginseng is the best/most potent).
The second batch had a stronger taste that diminished over 3 days and now tastes only very slightly metallic. This seems to support the information that some (most) plastics do not allow CS to remain ionic, but moldy bread (and the more in depth agar culture tests) should tell if that's true.
The third batch has a very strong metallic taste that is experienced as more of an after taste and I'm saving for experimental trails later on.
I still do not have even approximate TDS measurements as I have yet to go get my digital tester, but wonder if any of you long time users out there have better, easier, and more accurate testing methods than TDS approximation via conductivity testing.
I do have a 30V/0.4A P/S lying around that I would like to use for generation, but it doesn't seem to generate any CS no mater how long it's left on. When I get the electrical tester I will see if it's faulty as it was just "laying around".
Thanks all for looking into this and I do appreciate the different methods used and any results information, even if anecdotal.
Hopefully next post will have some moldy bread results.
P.S. Digestive enzymes seem to be faring well in my system since the daily CS regimen was started.
That's all I have for now
When I stop learning, plant me.
I'm already of less use than a tree.
