New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
Farrah Day
I am new to this area of technology, but have become intrigued by the TPU and indeed Dr. Stifflers work.
I intend to construct a small TPU. I have no problems with the components or fabricating such a unit, and although I have read much about these units, I have however, been unable to find enough details or an actual schematic for a TPU to initiate my construct.
To this end can someone kindly point me in the right direction (and/or link) to a schematic or suitably detailed diagram of a TPU from which I can make a start.
The generally accepted theory of operation would also be appreciated.
Given enough information for me to construct a unit, I intend then to detail my build and regularly update this thread as work progresses.
Farrah Day
"It's what you learn after you know it all that counts"
BEP
@Farrah Day,
Welcome!
There may be hundreds of theories. There are a few schematics thought to pertain to a SM TPU. None have been proved 100%.
Most are posted throughout this web site. If other information exists it probably hasn't been shared.
ramset
I believe user Wattsup has quite a library available here.
and poynt 99 also has data in a tpu specific thread
perhaps someone can post the links?[lost in a crash]
Chet
Thanks Grandma
poynt99
Quote from: Farrah Day on June 14, 2009, 07:13:39 AM
If you have read a lot about the devices, then you have most likely read all that is available. The inventor allowed some correspondence between himself and Lindsay Mannix to be passed on to the public, but no cookbook information was ever disclosed regarding hardware, and certainly no schematics were ever provided.
Unfortunately, you are in the same boat as all the rest. You must read what is available, view the videos, and make your own conclusions.
There are many theories abound, and you may jump-start your research from these if you wish. Those that have taken their theory to the next step and produced hardware prototypes, have as far as anyone knows, not resulted in a device that achieves overunity.
You may be interested in reading the "Spherics" thread as this may hold the key to understanding how the TPU works. I have written a WIP document based on his thread as well as my own insights.
Also, read the "Carl" documents, and pay attention to SM's response regarding tao's insights.
There is no known consensus as to: a) the theory of operation, b) the source of energy from whence it comes, c) whether sine or square waves are used, d) what the "kick" is or how to produce one, e) whether the rotating field is magnetic or not, f) what "perfect frequency" means, g) what frequencies are used and how many; 2 or 3?, h) whether it was all faked or not, etc. etc.
So although some progress has been made over the last 3 years, there are still many unknowns and very few people agree on anything.
SM himself stated that he was not sure of the source of energy. He certainly knew how to make the devices produce or convert energy, but whether he really knew why it worked is another question.
Good luck and welcome to the quest.
.99
Farrah Day
I see, I had assumed that many of you had a produced working units and expected at least a general theory of operation.
I've seen most of the SM demonstration videos - is it generally accepted that his TPU did what he claimed... or are there doubts to his credibility?
On reading what I have, my initial thoughts were that it would be the interaction with our planets magnetic field that comes into play, but all that I have read is very fragmented.
If I can just establish a few basics here:
The collector:  Is this basically a coil of heavy insulated copper wire, the load of which would be placed at the open ends?
Control coils: Are these (3?) small coils wound around the collector coil and spaced equally apart?  Are these control coils then pulsed at various frequencies (harmonics) in order to induce a current in the collector coil?
I read once that once the current was flowing in the collector coil that the unit became gyroscopic. In other words it took more effort than expected to move the unit or rather alter its angle in space. This would certainly suggest that there may well be an interaction with the Earth's magnetic field.
Spherics are the guys with the Mobius Loop TPU aren't they, which would seem to be a variation on SM's unit.
Are most people thinking along the lines that it is the back EMF from a fast decaying pulse to the control coils that gives the kick in the collector coil? And that at the correct frequencies this kick becomes enormous?
Is it in fact a mini particle accelerator??
Sorry so many questions, I'm just trying to pin down a few basics and understand what I am trying to achieve rather than blindly going about a build.
Farrah Day
