New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
Farrah Day
Quote from: zapnic on June 23, 2009, 04:49:11 PM
i believe control coils are  brakes?current brake?
like Stevie boy Say's something about sound barrier ?
and  extra power comes from inrush current ?
With the correct set up they might aptly be called 'control' coils, because not only would they initiate the process, but also could be used to stabilize and regulate the output.
However, SM's compact devices would tend to suggest he has everything pre-set, with no control (and certainly no brakes) other than deactivating the unit.
Regarding SM's TPUs not working upside down. Grumps said that SM's later units did not suffer from this problem, while GK pointed out that the 6" version seemed to function ok when being handled in all orientations, and with clearly no dimming of the load.  So, the question now is: Is the 6" version in the video a later version or is the whole upside down issue simply SM misinfo.
If the 6" version in the video is a later version, how could it possibly achieve the same result but not suffer this effect without radical redesign?  I smell a rat.
I'm now very much inclined towards the device tapping into ZPE via the creation of a vortex (or torsion fields) created by the interaction of the Earth's magnetic field (and possibly gravitation field) and the magnetic fields induced by the control coils. This seems as good a starting point as any and is the course I intend to initially pursue.
Newbie, you might find this link interesting if you don't already know about it:
http://freeenergygroup.com/?page_id=118
Farrah Day
"It's what you learn after you know it all that counts"
newbie123
Quote from: tsl on June 23, 2009, 05:19:33 PM
I'd like to hear more on that.
The CC warp the space-time around the collector (that's L) and ...?
Gravity is the only force that will warp space-time..     Nothing couples to gravity except (big) mass (or energy) so I doubt that is the case.  The Schuman resonance AFAIK has nothing to do with gravity.
Until you can measure it, arguing about something can be many things.. But science is not one of them.
Farrah Day
Hi Newbie
QuoteGravity is the only force that will warp space-time..     Nothing couples to gravity except except (big) mass so I doubt that is the case.
Granted gravity is not one of the most powerful forces in the universe, but remember that anything with mass exerts a gravitational force, and we all know that mass and energy are one and the same.
I'm not so sure the relative power of these forces is so important, I think it is maybe the void that is left if we disturb them that contains the energy.
Of course I'm probably wrong, but the way I'm looking at it is that it's like making a little hole in the bottom of a boat and having the sea rush in.
I see ZPE as always being there in the background - the very foundation on which our universe is built - but it is overlaid by all the other forces we are more obviously aware of, magnetism, electric fields, gravity, EM radiation. Poke a hole in any one of these and it effectively tears a hole in our space-time fabric allowing ZPE to rush through. At least that's the way I see it.
Newbie, I'm not sure if you're aware of the origins of the term ZPE, but if you're not google it. It's very enlightening - the energy available is unimaginable.
Incidentally, I've pretty much dismissed the Schuman resonance as playing any relevant part in the TPU. I'm focussing my attention on what happens when we create a situation whereby forces negate each other, ie the nulling of a magnetic field.
Farrah Day
newbie123
Now on more speculative note, I've seen weird reactions of ferrite (iron) to 8hz pulses similar to "Marco's dancing magnets" but with a xformer and LED. http://www.youtube.com/watch?v=mUJza3l8rmU
Grumpy
Farrah,
Now you have a place to start...
"tsl" made a few posts about interacting fields - check it out
Quote from: Farrah Day on June 23, 2009, 05:28:00 PM
        -Frank Edwards
