New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
Yucca
FarrahDay,
I´m not sure if you´ve read the thread below as it´s not in the TPU section.
Build such a device and it may give you gyroscopic action and unexplained voltage output way above normal theoretical transformer action.
Considering it is only excited by two 90deg phased pure sin of 1 freq the anomolous higer voltage is very strange since no switching inductive kickback is happening (ala joule thief). Also because only 1 freq is involved there is no possibility of hetorodyning. Also it was not overdriven so higher freq interference was not happening. The fact he reported higher voltage is very interesting despite it being only small current.
It´s a refreshingly straight talking thread, shame the main player (room3327) had the crap hacked out of his PC and left.
Some improvements are needed, like using a core material capable of much higher freq and so higher virtual RPM.
I will be building something similar using a handwound laminated metglass and insulating film core pretty soon and slowly posting any results on said thread. I will be makng the core quite thin so I can saturate it without biasing.
http://www.overunity.com/index.php?topic=6774.0
powerunlimited
To Farrah Day:
Be carefull not to fall into a trap, the spherics thread is SMs vehicle
to confuse and misdirect people.SM never worked with anyone he hid everything
fear that someone would steal hes secrets.
However it will give you a good view of hes thinking and mind.
Jack Durban also talked about SM being secretive and working alone.
giantkiller
I find this incredibly interesting. Who knows who is twisting who.
The multiple inductors in series has already been shown here 2 years ago. The notched pvc coil that Marco showed. That was 1 and was duplicated by JDO300 and I. Only 2 other copies of this intensely detailed marvel exist or so we've seen. It has 24 inductors in series or 3 sets of 8.
powerunlimited
Untill you can make a self sustaining unit,not tied to a power source
only then can you claim a victory.You lack leadership, someone who is flexable,
coherent,logical,structured and lacks ego.You have been tricked by SM,whos
been here since the beginning,setting traps
and the direction you go is in a circle.
Farrah Day
QuoteTo Farrah Day:
Funny you should say this as I've recently spoke to someone off-forum about this. My concern with Spherics is that his design would appear to be totally theoretical and why would anyone attempt to build an 'unknown' design from a concept when at least it appears that the original SM device worked?  It is only logical to initially try to replicate a 'more proven' device that is shown working.  Why Spherics would only post a couple of times and then be unavailable for further discussion also concerns me.
QuoteI find this incredibly interesting. Who knows who is twisting who.
There is more than likely a lot of misinfo on this forum, much generated through simple ignorance, but some carefully and intelligently deployed.
I have yet to confirm the SM coil layout.
QuoteThe multiple inductors in series has already been shown here 2 years ago.
Can you point me to this GK?
In a report by Ronald Schinzinger posted by Mannix, Schinzinger states, quote:
'It was difficult to determine how many hours the devices may be able to operate because the inventor ended the demonstration after 1.5 hours'.
This of course flies in the face of Durbans 19 to 20 mins max operating time.
This part of Schinzinger's report I also found interesting, quote:
'After the test the inventor cut the toroidally shaped device into segments (though not the controllor box located at the center of the device). These samples consisted of an array of circumferentially arranged coils and wires grouped around a core made of a cork like substance'
Note, no mention of radially wound coils. From the video I've seen it is quite impossible to determine the individual coils or cut wires due to the poor quality and low definition, but one thing that does strike me is just how neat the cut is.  The neatness of cut suggests only circumferentially wound coils were cut through. If you try to cut radial coils, there would have been wires pulling out and dangling - it would have been harder to cut through and looked a lot messier. Either there are no radial coils, the coils are fixed in a hard resin, or SM avoided cutting through areas of radial coil (which would indicate in itself that radial coils, if any, were spaced apart and did not actually meet).
Not sure what this piece could mean, quote:
'February 08, 2006
I will offer something that I personally think may be important. No this is not from steven but he says it is not far off. When somebody says "coil"
think of a "circular arrangement of wires"'
I assume that was coming from Mannix, but I do wonder if it has been edited as I'm not sure what the 'important' bit is supposed to be. I mean, doesn't everyone already think of a coil as being a circular arrangement of wires?  Bizarre.
And for Grumps this, quote:
'February 11, 2006
The coil gets hot. This problem has not been resolved. It is apparently due to the windings moving.'
Now moving wires rather tends to suggest that they were not wound particularly tightly and certainly not resin encased. Which takes us back to the neatness of the cut segments and the question: Are there any radial - so-called control - coils and if so can anyone provide me with a reference to where these are shown or  discussed by SM?
But ultimately I guess, we have no way of verifying who was saying what, if what was posted was actually said, or indeed if this is not all just misinfo...
Farrah Day
"It's what you learn after you know it all that counts"
