New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
innovation_station
so for this unit to run properly in a 1 ring configuration system you need a TRIGGER COIL ...
i would wind a 15-20 turn trigger coil on the the ringggg
if i were to multi stack this unit i would add each 4 coils of the next ring to the last ring on the secondary of the jt...
the collectors would add up aswell to the top  then would tap into the final winding over the whole thing and the magnetic feilds squeezing in on the pancakes are also pushing out on the final tunnel wrap witch is a generator tapping the rotating magnetic mess..
as it accelerates the colapse from the jt!!
lets call it a aaa JT driveing a TPU!  :D
SO BASICALLY WHERE YOU TAP YOUR LEDS ON THE JT YOU PUMP THAT THROUGH THE COLLECTOR AND PUMP IT!! ;)
to power the electro magnets and the trigger curcuit ..
you want to use the inputted engery from a BUTTON CELL OR A AAA to power the electro magnets the (50 turn coils)   all 12 of them  and you use the electromagnetics produced from both the squeezing effect and pushing out effect   as a rotating generator  pumping all the collectors 4 times each ring in 2 reveloutions  then hitting the trigger to do it agin
and as it turns off the cold engery or colapse from the electro magnetic feilds is rectified to dc and you pump the POSITIVE RECTIFIED ENGERY THROUGHH THE COLLECTORS ..  and squeeze it like OTTOS TEST
BOOOOOYAH!!
IST!
innovation_station
can i ask what sauron  was thinking ........ :)
lol
just another old picture....
innovation_station
ill finish the unit showen today and i will fully build the next one too
just cuz it seams nobody can or will
the second unit i broght to the top agin is  a 3 phase pump useing a 3 phase relay ...  it will turn on 15 coils per phase .. 123
im sure you see it if you dont i can further explain ...
ist!
50 turns sounds good on a sewing machine bobbin .. maybe 22 or 26 ga ...
so it will require 45 bobbins ...  a bit of work ...  nuttin im not used to ...
GREEN & RED  it must be christmas in july ...  :D
now i did say years AGO.... RESOSNANCE IS NOT REQUIRED!!!
well got the the coil all done 12  50 turn control coils on 3 rings ...  ran out of tape and i need some bobbins for the next unit  ;D
so i will keep at it as always
innovation_station
got all my bobbins 48 of them
thank you WALMART!! ;D  8 BUCKS 2 BUCKS A BOX OF 12 ...
ill take some pics of the bobbins im useing  the ground wire un sheilded and  the coil
b4 i wind it ...
ist!
in my last picture here i see 4 stops and so far 25 bucks ...   2 dollar stores ..  wallmart and the hardware store ...  :D
ground wire ... bout  8 bucks bobbins 8 bucks disposable camera (cap) and a cfl for the toroide ..  and the battery came for the camera   but i can simplfly it yet ...  4401  or a 2222  or a 3055 might work well ..
innovation_station
right i might aswell post this here too
i have this jt that puts out 700vac pure sine wave ... (peek to peek)  from a AAA battery ....
hummm
here is a scope shot and a picture of it
ist
i also herd an AA battery can deliver up to 26 amps on almost a dead short ...  WOW!  ...
i love being the village ididot ..  :D
i have some of thease too but mine are 9-18 on the input pulse  i bet it can run ac or dc ....  ;D
