New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
EMdevices
kooler,
how often does the neon and SCR fire?  It's in the Hz range, correct?
EM
kooler
its a small transformer...
it fires 2-3 times a second
i think...
i have not played with it to much
been a bit under the weather
you can use the output thru a diode back to cap to make it fire faster...
it just takes about 15-30 seconds to wind up... that was what i was doing with a 150uf 400v cap
kooler
i forgot to say that yes this is just a few hz.
but this isn't what i am collecting from
there are two extra coils mounted on this aircoil
one on top and one bottom... and they both hook to 1-2 transformers
onced induced the hz quad triple...
you collect your output from the top or bottom coils...
i'll keep you all updated soon as i get to do more
tsl
Quote from: Farrah Day on June 29, 2009, 06:59:21 AM
Thanks Loner
Anyone ever heard of the Tolman-Stewart experiment?
A very long wire was connected to a very sensitive meter. The wire was then rotated at 4000rpm. The long wire length allowed it to twist together as it spun. The coil was then brought to a stop in a fraction of a second.  The result was the conduction electrons carried on moving after the bulk of the metal had stopped.
These moving electrons produced a tiny pulse of current through the coil that was measurable on the meter.
Tolman and Stewart then analysed their data to find the charge to mass ratio of the current carriers in various metals and found these agreed with the known charge to mass ratio of the electron in free space.
On a slightly different note, does anyone else have a problem with the generally accepted SM design of the control coils being wrapped radially around the collector coils?  It just seems to me that in this configuration, the magnetic field induced by the contol coils into the collector would be far from optimum.
The way the coils are wound will no doubt be of utmost importance given that there appears to be very little to a SM TPU.
Bifilar winding configurations may well play an important part in the operation of the device, as on the one hand we can have a bifilar coil connected in such a way as to cancel out the inductive reactance and hence be left only with a pure resistance, and on the other hand a bifilar can be connected to get the magnifying effect Tesla spoke about whereby the coil can store many times the energy of a standard wound coil.  Two very interesting effects.
hello all again,
it's been a  long time for a reply on this post i know, but i've just found it so here it is
for the ones who are still following this see the attached pdfs on stewart tolman effect
if one jerk (fast and short acceleration ) a piece of conductor u'll get a current in the same direction as the movement.
sm talked about a piece of wire a source of current the magnetic field of the earth a mean to see whats comming out from that wire. now see it that way u have a conductor( wire) placed in the earth's magnetic field so that it will jerk when the current pass. attach a osci to the wire but so that u can see the stewart tolman current(direction of that current is the same as the jerk direcction).
so there is a kick
if u want to make another setup take a loop of iron (a conductor and also magnetic) take a biffilar coilsetup(as per spherics posts) arround it and pulse that biffilar coil so that the iron loop is magnetized by the first pulse and before that one is gone the delayed pulse will jerk the conductor getting you the current u're looking for. take 3 biffilar setups arround the loop so that u can jerk the iron conductor faster and u'll get that pulsed dc output and the vibration and the giro effect and if the iron is big u'll get also some problems with eddy currents. all things sm is talking about.just my 2 euro cents
cheers
tsl
One more thing.note that the "induced" current is not interferring with the initial pulse.one can use the resulting pulse to pulse the kicker coils to generate another pulse resulting a positive Feedback.also no Lenz coupling between the collector and the Kicker coils.
tpu = tolman Power Unit ?
Cheers
