New TPU build
Started by Farrah Day, June 14, 2009, 07:13:39 AM
powerunlimited
o Farrah day
            The tpu that was cut up was a come on ,a ploy by Sm, notice
that it doesn't look like the other one in the earlier part of the video.
He made this one for the express purpose to give the investors a piece,notice big lack of parts,to get them to bit.
Pay attention in the video to the box at the bottom,in the unit they cut,thats the main
unit that is the key to this device not the wiring.The deal goes like this it malfunctions,he says
i don't know whats wrong its defective,i will give you a piece of it since its no good,
if they asked for the box he would say ,
thats the control box i can only sell it to you if you buy the rights.
the investors go away and head to there engineer and ask can you figure this thing out from this part.
This is exactly what SM calculated they would do.The wiring in the piece is an obfuscation,worthless.
This  device is like one big soap opera,the wiring could be thought as an antenna of sorts
longer wire more output,higher voltage,higher current.Thats why the big tpu's put out more power,
the small ones have smaller lengths,so lower voltage,lower current,thats why the torroid shape.
I think your getting the point on misinformation here
In regards to heating it maybe have been due to load,the 1.5 hour may have been under a smaller load,the one jack durban
saw may have been under a much higher load.
Farrah Day
QuoteIn regards to heating it maybe have been due to load,the 1.5 hour may have been under a smaller load,the one jack durban
I don't know, Durban seemed pretty adamant that each and every TPU only operated for specifically 19-20 mins under any condition.
I'm sure the interviewer asked Durban at one point, what happened if the units were left running past the point they became too hot (at the point many theorise would cause catastrophic meltdown) and Durban replied that they just shut down??
I'm getting a feel for things now, and things are slowly becoming a little clearer to me.  When I first read the Spherics thread, I was quite amazed by the guys insight and apparent intelligence... but, on reviewing it numerous times I got the 'too-good-to-be-true feeling about it. It's too carefully and well-written for someone to go to that much trouble and then mysteriously disappear - it does not make sense.
When I first joined I wondered why Spherics had TPU-Elite status after only what... 2 posts?  Then I realised you get this status if Hartmann pins a thread. What, for the life of me, I can't understand is why Hartmann in his wisdom would pin the thread of someone that shows up out-of-the-blue with an unproven theoretical model and just a couple of posts to his name.  What is that all about??
Spherics stated:
QuoteFirstly although this has been mooted I am not Jack. All I will say is the interview says more about the character of Jack than it does Steven Mark
This statement I believe is very clever, it's the equivalent of the misdirection a magician employs to draw your attention to the wrong place.  If Spherics had slated Durban too much, made it look too personal, it would have been obvious to everyone that Spherics is actually SM.
So he does it in a very clever way, which subtley misdirects us and does not detract from the credibility of the post. Basically here SM maintains his composure like a true pro, which falls in line with the SM character that Durban describes.
To me now it does seem logical that:  Spherics = SM
If this is the case, then SM was clearly not here as himself to openly reveal the secrets of his TPU. Therefore it is only logical to think that in his psuedonym guise SM was here for one purpose only, and that is to provide a whole wealth of misinfo.
It might be a good idea for everyone to review their thoughts on Spherics and concentrate on the original TPU designs. I know I am.
Farrah Day
"It's what you learn after you know it all that counts"
powerunlimited
to farrah day
As I warned you SM power of illiusion is very powerful!
As to the differences between Jack durbans account and the other guy,I don't know,we would have to know the load exactly in each case or in one.As to it shutting down possible ,if wire gets so hot it melts that causes an open circuit.If its at the output part and if that supplies power to an oscillator,then yes it will shut down ,as to weither its a temporary shut down or totall inoperative shut down I down know.No wait I read somewhere he put in a thermal shut down device
in the big tpu to shut it down if it got too hot.Thats why it shuts down so it won't burn up.
Farrah Day
Yes, a thermal shutdown device on each TPU would make sense, Durban touches on that in the interview.
Is it likely that Mannix was also SM? I ask as I found a thread started by Mannix, to which an 'Earl' very politely posted some very sensible and legitimate questions, only to have Mannix never respond.
Can I just ask again, has it actually been verified anywhere that the unit consists of collector coils around which are radially wound smaller 'control' coils?  Or is this all just speculation too?
This is rather like panning for gold, you have to sift through tonnes of worthless sludge in order to hopefully find the odd nugget.
I'm sifting, I'm sifting... no nuggets yet!
Farrah Day
Farrah Day
I think maybe I will have to go about this in a different way as it seems that there may not even be any unniversally accepted fundamental coil design to work from.
If anyone knows otherwise pleeeaase speak up.
Working on the premise that the secret lies in the interaction of magnetic fields, the question I guess is: What exactly are we trying to achieve?
Farrah Day
