AC from Joule Thief Secondary/pick-up
Started by jeanna, June 16, 2009, 03:11:33 PM
jeanna
I have saved a burned out spot light. How do I connect it up? The little button on the bottom and the threaded side wall? Can a joule thief?
I have lots of them that have 333khz and higher. All I need to do is ramp n amp it up with more coils I think...
Wanna help? (I realize you are moving. It is hard now. It is OK to save this til later too.)
jeanna
innovation_station
you know i will help any way i can ...
but this is an easy job ...
we just need a tiny tesla coil ill show you scary power ... lol
there is 1 reason and only 1 why the t coil is not ou ...
lol
cuz   who has rectified it ....  ;) :D   if we had a t coil with properly spaced contacts to diodes...  well
i need not say more on that one ....
ist!
Doug1
Innovation on that note
  May I suggest a revisit to Avromenko's pat 6,104,107 and his use of the blocking capacitor typically it is used in transmission of data and relates to dc over ac signals and the probability of dc cumulative effects when signals are sent too close together and create a log jam. you going to run into the problem when you apply the idea to a real load. or at least keep it in mind for when you find yourself getting unexpected results.
altrez
Hello all..
I am glad you have the AC thread going. I like the idea of the Tesla coil. The AC is a very cool part of the pickup coil!
-Altrez
stprue
Quote from: jeanna on June 18, 2009, 09:45:06 PM
Actually jesus,
the point of showing that 2 tier circuit is NOT that there is anything sacred about it. In fact I have moved some wires and pins around a couple of times since the beginning.
The point of examining it is that it is an example of the concept Tesla was trying to put out in his 1892-4 lectures.
It is possible to have 5 different outputs and 5 different voltage/frequencies coming off ONE AC line. (more too)
This is what I want to explore.
I think when you have an ac circuit you are able to make a branch in a parallel way that delivers whatever voltage and frequency you want, just by playing with the inductors and probably some caps for extra oscillation within just that segment of the overall circuit.
This kind of thing is being done in our electronic doo dads. They have a wall wart that rectifies and steps down the voltage to 5 or 10 or 3 volts and then the appliance runs just fine.
My thinking is that we can follow that very same plan and use ac. and that way all the current returns to the source except for the eensy bit that the appliance actually took.
But this is my idea.
Please explore yours if you have a different one. And join me if you would like to.
jeanna
This sound very interesting to me and looks to be the right direction to be heading.  When you say back to the source is this being done on a secondary=rectified into a battery or cap. while the primary AC is used and changed to power a load?
