Magnetic motor?
Started by helioc, June 16, 2009, 06:49:50 PM
mscoffman
Quote from: lumen on June 23, 2009, 10:11:52 AM
Actually, It's because I have only tested the data twice and until I can confirm the entire cycle I thought it best not to waste everyone's time.
I think you are doing the correct thing, lumen. It is insufficient to show
energy gain over part of a cycle. We need to show how the parts of the
cycle can be put together to retain excess energy around the whole
loop. Despite claims, the energy balance over the rest of the cycle
is never very obvious.
:S:MarkSCoffman
lumen
Well, I've done all the testing and collected several levels of data and it still looks to be OU.
I believe the next step is to build a device that uses this principal and verify if this can actually function as the data suggests.
I will first do a sketch that shows the process so anyone interested can verify it also. It should be easily replicated since the data suggests a very high yield of output. Yes, I am skeptical also, but the data tells me otherwise so now I will build it!
Maybe I should start a new thread?
ramset
Lumen
Thank you for your great attitude and willingness to share your work!
Releasing an idea to scrutiny is not easy
IMHO a release in this thread for said scrutiny,would be a good start!
Then of course a dedicated thread
Chet
Thanks Grandma
lumen
Ok, This is the concept I have been testing. All tests indicate it is actually OU and even though the data shows this, I will remain skeptical.
It appears to be easily implemented in several different types of devices so building something should be easy. It may be simplest to build something that just makes a single movement and resets and re triggers itself. Or even rotary like a "V" track motor only maybe something more like an "S" track or "V" track with a skip in it.
Well anything running non stop would prove the concept.
lumen
The small magnets I used for testing this principal indicate that each transaction would have the output energy to lift 1kg .05 inch. This is a result of about 15 to 20 percent efficiency.
The large magnets were .125 x .5 x 1.5 N45
A device using 10 configurations operating at 3000 RPM would have the ability to lift 1kg 25 inches each second. That would be a useful output even using these small magnets.
