Claimed OU circuit of Rosemary Ainslie
Started by TinselKoala, June 16, 2009, 09:52:52 PM
0 Members and 80 Guests are viewing this topic.
Hoppy
Milehigh: -
Having studied John Bedini's copius articles and forum postings, it dawned on me a long time ago that his overunity claim seems to be based on the argument that if one conditions a battery or bank of batteries with HV spikes from a monopole motor / charger for long enough, then the intenal resistance will reduce considerably, thereby substantially improving the overall capacity of the battery / bank of batteries. Because this cannot be achieved with conventional DC charging he attributes this to the 'unique' charging waveform from the monopole motor / charger, underpinned by his and Tom's grand new age 'free energy' theory.
Those people able to properly understand and apply basic electical principles soon establish that although the batteries do indeed improve from continuous conditioning in terms of capacity gained, there is absolutely no OU in the overall system when properly measured 'front to back'. However, when energy is computated using one of the various load test methods and procedures posted on the various forums, OU can sometimes be seen but this is just an illusion because of complex waveform measurement problems. This is because the front-end of the monopole is ignored and measurements are taken from the monopole output into the battery and energy calculated and then compared to energy extracted from the batteries under load.
Unfortunately John Bedini has never to my knowledge detailed or approved any load test method and procedure. In cosequence, various load testing regimes are adopted by experimenters, all of which are claimed to be fit for purpose. However, he is on record as saying that the energy consumed by the monopole motor / charger must be accounted for in total before comparing with that drawn by the load, Despite this, many experimenters still appear to ignore this important advice!
Hoppy
.99:
I heard that the US Navy's submarines all run on top-secret "magnetic motors" and need no fuel.  What most people don't know is that the back-up power plant is an OUBB system.  This system is almost never used though because of its distinctive audio signature that can be picked up with today's sensitive hydrophones.
MileHigh  ;D
poynt99
MH,
:D
Seems the thread at EF has all but died. Rosemary doesn't post much there either. Why is Aaron taking so long I wonder? Seems he's spending more time on the tangents he finds himself on than testing the task originally at hand. A stalling tactic? But why ??? COP of 17 should stand out like a tube amp at a MOSFET convention.
.99
fuzzytomcat
Hi everyone,
A parts up date ...... as far as I can tell "no one" has sourced or acquired the 10 OHM resistor in the RA circuit -
The load resistor was made by Specific Heat CC (SA). It comprises a 10 ohm hollow core wire wound ceramic structure with a length of 150 mm (5.9055 in long). and a diameter of 32 mm ( 100.5308 mm / 3.9579 in circumference). 48 turns of resistance wire (4825.4784 mm / 189.9795 in / 15.8316 ft long) are spaced at 1 mm. It was chosen for its inductance (8.64 micro Henries).
I have sourced a resistor similar to Aarons and will be getting it Monday or Tuesday for group data comparison ....... BUT ....... being my son is a "glass blower" I have access to this .......
I will be "MAKING" the proper one using the following parts which should be more than adequate for this replication -
____________________________________________________________________________________
"Borosilicate Glass Tube" ( Pyrex )
32 mm OD. x 26.4 mm ID. ( w/ 2.8 mm heavy wall )
"Nichrome Wire"
10 ohms @ 15.8316 feet = .63165 ohms ft
AWG 20 [.032 dia] ( .6592 ohms ft ) = ( 10.4362 ohms ) "Ni Cr C" 60% nickel, 16% chromium, 24% iron
AWG 20 [.032 dia] ( .6348 ohms ft ) = ( 10.0499 ohms ) "Ni Cr A" 80% nickel, 20% chromium
"Counter Totalizer"
Durant - Part Number E402400
If anyone is interested or have comments please feel free .....
Regards,
Fuzzy
.99:
Why?  Why?  WHY!?  *sob*  lol
The second mystery is what happened to TK?
Rosemary just asked you to account for the battery voltage increase during TK's last clip.  It's a Fifth Column!!  She is looking to create discord over here in Oceania!  ;D
Tangents are a comfort zone, like a teddy bear.  When things are looking shaky, you can always plug that trusty diode into a charging battery and watch the voltage go up.  Ahhh.
Quote(A) COP of 17 should stand out like a tube amp at a MOSFET convention.
A COP of 17 should stand out like.... an M1A1 Abrams tank at a WWI military hardware convention.  ("E" for effort lol)
