Claimed OU circuit of Rosemary Ainslie
Started by TinselKoala, June 16, 2009, 09:52:52 PM
0 Members and 52 Guests are viewing this topic.
BEP
Quote from: MileHigh on September 23, 2009, 07:38:22 PM
"Coriolis effect" and other elements of that interferometer discussion, I wanna hurl!  lol  I wonder what percentage of the people in the discussion even know how "classical" vanilla gravity works.  Just gravity, forget about zipons and unified field theories and gravity waves.  How many posters really know how basic gravity works?
@MH
I'm curious.  Do you know someone with a complete and unfalsifiable theory on vanilla gravity? I don't. I do know many claiming to know.
'Gravity waves' is a very poor name but recognized by most.
As far as your tunnel.... Your mass will be attracted to the greatest and closest mass with respect to your mass. In other words... if you found yourself in a small bubble in the center of the Earth's mass there is a pretty good chance you could wind up as paint on the inside walls of that bubble. If your body held up and you maintained exact center you would float in the middle while be pulled from all directions.
From some of your posts I could guess you've been there?
No matter... If I find something that is hurl-peutic I'll give you fair warning so you can prepare with a large meal  ;)
Rosemary Ainslie
Quote from: BEP on September 23, 2009, 11:26:51 PM
@MH
Just felt this needs re-iteration.   Lol.
the_big_m_in_ok
Quote from: witsend on September 23, 2009, 09:21:31 PM
Hello to you too Lee.  See if you can get Stefan to add more emoticons and allow signatures.  That would make this site nearly perfect.
Hey witsend,
I used to be a computer technician and programmer.  I don't know how much control the Moderators have over the software, but if they don't, a software rewrite is in order.  Expensive.
Just a little more control over the trolls and it would be perfect.  I've added my vote to this but my applications are ignored.
Well, hartiberlin is running the show.  I don't used the specialized feature much, anyway.
--Lee
.99:
Looking forward to any new videos from you.  When everyone does clips with the new PCB setup it should be really interesting.
I am burned out on oscillations, periodic or aperiodic.  Do you remember how the "straight" test was supposed to give you COP 17 and the oscillations were supposed to produce an even higher COP?  A bird in the hand is worth two in the bush.  No birds, just bushes fluttering in all the hot air.
No comments from Jibbguy about how accurate pure analog integration can be without the sampling and quantization issues?  I'm stumped.
Rosemary:
I sense that you are still emotionally involved with this project, but I'm not.  I am just having some fun and you have to cut me some slack.  Just go with the flow...
I'm a troll, you're a troll, everybody is a troll, what the hell is a troll?  Are they second-class citizens and you are the judge of who is acceptable or not?  Should trolls be put into designated fenced off areas?
BEP:
Forget about gravity theory for a second, and how about just understanding how it acts for starters?  If you understand how it acts you have a lot of insight into how it works.
QuoteAs far as your tunnel.... Your mass will be attracted to the greatest and closest mass with respect to your mass. In other words... if you found yourself in a small bubble in the center of the Earth's mass there is a pretty good chance you could wind up as paint on the inside walls of that bubble. If your body held up and you maintained exact center you would float in the middle while be pulled from all directions.
MileHigh says that you are a MillionMiles off base with that statement.  Super wrong.  It's a pie-in-the-sky statement.
My God, the resistor can light up a CFL.
I plucked this comment out of the ether:
QuoteOut of curiosity, has anyone tried a plain inductor on this circuit in place of the resistor? Resistance slows down the charging of an inductor, so if you increase the inductance - you would need less resistance for the same operating frequency.
Funny, I thought that resistance speeds up the charging of an inductor.  Hmmm...  I also thought that we wanted a resistance to produce heat....  Hmmm.....  My Spidey Qualifying Senses are tingling...
Enter Harvey into the picture:
QuoteA series resistance limits the maximum current the inductor can pass thereby limiting its maximum charge value - this will cause the inductor to charge faster, but never reaching saturation.
Harvey gets five Brownie Points and eight Demerit Points.  Shucks!  (I am assuming that "never reaching saturation" is a "Harvey concept" and not the theoretical concept which is correct.  If Harvey meant the theoretical concept then he is awarded eight Negative Demerit Points to correct for the eight Demerit Points for a net five Brownie Points.)
Somebody said this:
Quoteuses a small amount of battery power maybe .01 volts every 4 to 5 hours
Sacrilege!!!
Quotehad bad results because it calls for two (2) 12 Volt "Liquid" lead acid 10AH batteries and needs them for the circuit to work better I think it has something to do with resonance.
My batteries have a five octave range and can compete with still way hot Mariah and way too cool screaming bitch Adam Lambert.
QuoteEveryone - MORE GOOD NEWS. Lisa has extended the loan of the TEKTRONIX TDS 3054C DIGITAL PHOSPHOR OSCILLOSCOPE until the end of November.
I GET 100 BROWNIE POINTS!!!!!!  Results in 5 weeks!  (Oops!  9 weeks!)
QuoteCrazy idea : maybe resonance poll electrons from 12V battery which is connected through ground wire...
Actually it's a bogus idea...  The notion that if you connect up to earth ground you somehow get power from the ground itself.   That idea took off last year when people started playing with ignition coils and CFL lights and ground wires.
Still waiting for those magic heat pies to be materializing out of thin air from the inductive heat pipe.
Stream of consciousness meets the ether streams.
Rosemary Ainslie
Hello MileHigh.  You've excelled yourself.  Let me tell you about the troll.  He's an ugly little subhuman that lives under the bridge.  And when people try to cross this he jumps up and eats them.  I take it you've been sharpening your teeth.  But I must admit.  I think you're more brat than troll.  And don't lecture me about judging anything.  I'm a poor second to your talents here.
As for the rest of your post - a stunning mix of innuendo and poorly quoted nonsense.  Don't you get tired?  And you ask to be cut some slack?  Good heavens.  Who then can criticise the critic?
Sorry I should have added 'innuendo, nonsense and BAD SCIENCE. :o ::)  If you were an authority here I'd be interested in your opinion.
