Claimed OU circuit of Rosemary Ainslie
Started by TinselKoala, June 16, 2009, 09:52:52 PM
0 Members and 27 Guests are viewing this topic.
Rosemary Ainslie
Quote from: MileHigh on September 26, 2009, 01:37:17 PM
Rosemary:
I read through it once, an sort of caught your drift, I will try reading it a few more times.  Let me just make a few general comments.
You can think in terms of electrical energy and heat energy and chemical energy.  There are some fairly simple analogies that some to mind.
For the heat energy, you can imagine the amalgam of the ceramic in the resistor like a bunch of billiard balls in a three dimensional random matrix.  They all stay in their respective "courts" and continuously smash into each other in a random fashion, and this goes on forever as long as you are above zero degrees Kelvin.  How rapid and violent the continuous smashing is is a function of the temperature.  The key thing is that these are "ideal" billiard balls that undergo what are known as "perfectly elastic collisions" with their neighbours where no energy is lost when there is a collision.  That's basically what heat is.
For chemical energy, now you start to think of the individual billiard balls as having their own innate stored energy, that is normally kept stored but has a potential to be released.  You know the little triangular thing that you made with five Popsicle sticks as a kid?  You started off with a triangular shaped arrangement of three Popsicle sticks and then slipped two Popsicle sticks across them to make an arrangement of sticks that held together under it's own stress.  When you threw it and it broke apart on landing, it "exploded" releasing the stored up energy.
The burning wood is just molecular "triangles" breaking apart and adding more energy to the heat billiard ball game described above.  When a chemical reaction takes place, two molecules might eventually become two new molecules that fly away from each other at high speed - and they crash into the billiard ball matrix and add more bouncing energy into the mix, raising the temperature.
The electrical energy being converted into heat energy is simply moving electrons converting their electron-volts of energy into heat energy by smashing into the random matrix of the continuously colliding billiard balls.
That's a simplified view of what I see going on at a microscopic level.  All of the energy action is mostly mechanical in nature - that's what heat really is.  Burning wood is just the billiard ball game going completely haywire, the amalgam, a.k.a. the random matrix gets broken apart by the extra shaking going on and the "triangles" start exploding everywere.  Some of the solid amalgam changes in "phase" from solid to liquid, and from liquid to gas.
Oops, I should also mention that photons are swimming around in this billiard ball game matrix soup also, and when the triangles start popping, photons start getting emitted like crazy, sometimes smashing into billiard balls and "disappearing" or sometimes making their way out of the amalgam.  This is the EM energy radiated away from the amalgam.
;D
witsend
edit  ::) ??? :)
Rosemary Ainslie
Quote from: poynt99 on September 26, 2009, 10:50:09 AM
Rose, it requires some insight, but it was not that difficult. I simulated the output section of the 555 timer chip and used that to drive the "MOSFET". I included the heavy current limiting resistance that Fuzzy and Aaron used on the 555 VCC pin. The 555 output section is what is responsible for that "reversal", when heavily "limited" with that series resistance in VCC. If the guys had scoped the MOSFET gate, they would have seen this.
Thanks for the positive feedback Rose. The hostility I'm receiving at EF is becoming a bit too much.
You can post a link there to the post I made with the scope shots. Copy and paste this in:
http://www.overunity.com/index.php?topic=7620.msg202337#msg202337
.99
Poynt - I can't do the bended knees thing again.  I'm waaaaay too old.  We need your post IN FULL.  Say you were pressured by persistent admirer - and then add a disclaimer.  Just say you'd gone off on a tangent and that you never meant to leave us after all.  Don't worry.  Only Harvey and I read you at the moment.    ;D ;D ;D
EDIT and a really cool kitty cat
2nd EDIT  - and some monitors
3rd EDIT -  ;D
Rosemary Ainslie
I'm only just now realising that after a certain time one can't even modify a posting.  I'm so sorry I was flippant Poynt.  If I could have I would have done some major editing there - and for that matter on MileHigh's posts.  Sorry guys.  Especially to Poynt.  Your skills deserve better treatment.
Just know that I was only teasing.  I think your work here is excellent.  I just wish - in all sincerity - that you'd post it all on Energetic forum.  Perhaps someone can oblige.  It's beyond my skills and I'd prefer to see the raw data than the link.  Maybe Fuzzy?
fuzzytomcat
Quote from: witsend on September 27, 2009, 01:39:39 AM
Hi Rosemary,
I updated the posting of mine ( http://www.energeticforum.com/69091-post2810.html ) and modified it show now all of .99 documentation from his posting here at Over Unity ( http://www.overunity.com/index.php?topic=7620.msg202337#msg202337 )
Thanks again .99 ..... great work !
Fuzzy  :)
Rosemary Ainslie
MileHigh - I hope I've posted this correctly because I'm hard copying it from my other computer.  ON MARKO RODIN
http://www.youtube.com/watch?v=pz_4ePRHT9U
FINALLY GOT IT.  Marko Rodin - Nassim Haramein and Jamie Buturff at Tesla Tech
You may want to see where cutting edge thinking is at the moment.  You need to work backwards because I've only got one clip here in the middle.  What's interesting is that Nassim Haramein has actually found the unifying principle and his friend Marko Rodin claims to had found the 'super particle'.  Anyway - it's a proposed reconciliation of quantum and classical theories.
EDIT THANKS FUZZY VERY MUCH.  Just seen your post.  :-*
2ND EDIT.  Sorry - you did this some time back.  I missed it.  Just know I'm half blind half idiot.  Anyway.  Yet again.  Thanks very, very much Fuzzy.
