0 Members and 39 Guests are viewing this topic.
verpies
Quote from: T-1000 on January 01, 2012, 10:30:05 PM
Due language barriers it is impossible to write clear instructions. Not enough, it is even harder to get right type of ferrite for working experiment.
I am aware of the language barrier.
That is why I did the English rephrasing and relieved the Lithuanians/Russians/Poles from struggling in non-native language.
While rephrasing the instructions, I marked the technically unclear sections in color - yet nobody clarified it for months.
If you cannot answer the red questions it would still be a great help to just write "YES" or "NO" next to the added blue words in the rephrased instructions listed in Reply #9510.
P.S.
It is easier to obtain an identical ferrite core, than get the correct tuning instructions.
ronotte
@acca,
thank you very much for suggestions. I've seen your videos...OK.
My HV test environment at the moment is very, very easy as well. I am using a very small LCD driver module that output about 3-4KV @ 35-40KHz (sinusoidal) drawing only 0.2A @4V so input DC power 0.8W. That output is fed to a 1KV standard arrester that in turn drive the resonant (3.6MHz) Caduceus coil. The output on secondary coil, just after the HV diode (and levelling 3n/10KV cap) is a steady DC 500/600V with peak at 2 KHz rep rate reaching more than 1KV. The lamp load after a second arrester is subjected to 0.2usec positive spike only at same rep rate: hence it does not glow as duty cycle too low. I've to take pics and show them.
@all
for the next 5 days I will be on vacancies so I will be not able to follow the thread
Roberto
stivep
Quote from: Hope on December 31, 2011, 04:12:00 AM
Wesley can you share your groups latest work and also was the effect gravonic that you witnessed that was so exciting?
There is always a silence before the thunderstorm.
I'm not sleeping .Verpies  and few others made me be partially silent on the forum.By that time I was progressing. Arunas T-1000 is possibly better to ask  any questions. The man is brilliant.
Wesley
verpies
Quote from: stivep on January 02, 2012, 09:33:53 AM
I'm not sleeping. Verpies and few others made me be partially silent on the forum.
A true scientist should not react emotionally - especially to constructive technical criticism.
Hope
Quote from: verpies on January 01, 2012, 04:35:43 PM
How about some food for those of us who are stubborn and keen on achieving the same experimental results as the STAAAR team. e.g. clarifying the instructions in Reply #9510
How about the yoke device?  Are there (IYHO) enough docs to build one from?
