dllabarre
Quote from: dole on January 05, 2012, 08:03:13 AM
Apologies for slightly nonrelated link but I found it dreamily fearless and at least entertaining, I hope
http://www.youtube.com/watch?v=FeO11z_gzLs&feature=BFa&list=PLF2ABF78C4A94E576&lf=plpp_video
d.
Thanks Dole for the link
I thought it was very interesting.
DonL
Hope
Quote from: verpies on January 05, 2012, 04:05:37 PM
The problem with the CRT as a HV capacitor is it low capacitance to volume ratio, because there  are no conductive parallel plates close to each other inside.  The ESR is not terrific either.
The breakdown voltage is high due to the vacuum but capacitance is low.  It could be used if it's sufficient and the user puts up with the sheer bulk of it.
USE this CRTs capacitor at your own risk!  Dangerous currents will be stored.
two crt's placed face to face place a aluminum plate between the front glass(s), charge the masks by charging the aluminum plate, would be a much higher value capacitor.  These will be high current dischargable so watch out and don't be careless.  If you are not well versed in HV safety practices this cap setup will be a dangerous endeavor.  But it also will be a very high storage device as well.
lonemoon
How wonderful can it be if someone can  make a new thread and compile all these ideas into a downloadable pdf file with all the needed materials, pictures and a step by step guide of replicating one.
sorry my head cant take all the inputs im reading from all the hundreds of pages. =/
jegz
Quote from: lonemoon on January 06, 2012, 07:07:34 AM
MY SENTIMENTS EXACTLY!!! a  pdf  is much better than a series of fuzzy webcam videos of a confusing  workshop setup. Another issue is how there are conversations in lithuanian in those videos...dont get me wrong, English is not my first language, but tell me how Wesley would feel if me and my buddies made a video of a promising new technology...but half of it was in an African language???.....Free energy replications should not be the preserve of  scientists, laymen should also be able to do so simply, just like how someone can drive a car without needing to know how the car works fully.
Sir, simplify your presentation and the message of Kapanadze will be unstoppable.
I see your videos on youtube, and the comments i see you responding to well are those of encouragement. those with constructive criticism (like "hey, improve video quality please" or "hey, how about making your setups simpler/more organised" seem to get a harsh response from you. we mean well and im sure you do by your actions, but you are a citizen of the world, not only lithuania.
keep it simple bro.
thanks in advance
dole
Hallo (little bit lazy so time to go back to work) reason I write this is for help from someone.
Roughly:
Pulsing an coil (what I believe TK is doing)  at certain frequency (depending on wire properties) will not “see” the load connected to the captured BEMF
what may be stored in the capacitor and dissipated to the coil/load due to standing wave at specific pulse frequency in the pulsed wire as I believe.
Whatever it is 1 or 1000 turns.
Further, captured BEMF dissipated at short pulse will again produce large BEMF and may be captured and feed back to source (capacitor) and discharge magnifying the primary captured BEMF.
As I see the tiny potential gain in such system I appreciate for help in the subject.
Reason for that are that 12V systems will not generates needed SG from BEMF
Does anybody may point to good robust schematic for 220 VAC converted to 220VDC (probably over 300VDC at AC RMS)
with some good amperage and components (MOSFET) what would withstand described above and attached schematic?
http://www.gotopower.net/disc_viewt.asp?mid=552
http://forum.allaboutcircuits.com/showthread.php?t=8424
d.
Don, thank U2 and 2 all of U.
