wattsup
Quote from: woopy on January 05, 2012, 06:03:27 PM
My 2 cents
perhaps this can help
good luck at all
Laurent
http://youtu.be/hypYLyA6SII
@woopy
Thanks for posting your video. I tried it right away and here is a small video. IT WORKS and now I have variable frequency, width and amplitude. I know there is some room for improvement but at least I can get some more experimenting done while other components are on order. Happy days ahead. lol
http://www.youtube.com/watch?v=m_CCg3TuA4Y
When turning off this set-up, it is important to shut off the power supply first before you turn off the FG otherwise you could get a strong flyback return spike from the flyback transformer going into the FG and burning the outputs.
@verpies
This does not mean I am giving up on that circuit you showed with thanks. Of course the circuit in question will provide better and safer control for the FG.
wattsup
ronotte
Quote from: wattsup on January 05, 2012, 01:36:40 PM
But geez, there has to be a way to pulse a mosfet with the FG on the gate and the feed supply through the drain/source without having to use such mosfet drivers. I mean why is there not a way with a few resistors and a diode somewhere. Maybe using a dual coil toroidal 1:1 transformer between the FG and the gate. I don,t know but you would think since so many years guys would have figured it out by now
wattsup
@wattsup
I did lot of work driving mosfets like irf820, 840, etc simply using a small commercial (low cost) 'pulse transformer' (5KV isolation) with easyoutput  DC level auto-restoration (alternatively it is also easy to wind small ferrite ring with equal effectiveness). I used it extensively for TPU 3 freq generators/switchers. Same approach can be used to drive easily halph bridge or full bridge switchers. It is a quick and safe way. I could send you detailed info.
Roberto
wattsup
@ronotte
Yes please send it to me at contact(at)purco.qc.ca with thanks.
@all
I changed the wiring on my flyback primary as shown below. There are fours coils, two on two all wound the same way and separated by the core gap.
I am sure that if my flyback had only one HV coil it would be producing more output then the way it was built now with two lower voltage stages. I am thinking that it will ultimately be easier to make my own flyback if I ordered the core and wound my own HV coil or maybe even order one ready mode from
Well the learning curve will have to be reset to zero with this variable sparking. There are many factors to consider.
One is spark gap material like the screws I am using now will not do at all.
http://old.4hv.org/index.php?board=18;action=display;threadid=2913
My set-up has no diodes or capacitors for the time being. I plan on adding them one by one so I can see all the differences between them and get a better idea on what TK had to go through to make such a device operational. The spark type, distance are one thing but the actual HV conditioning is probably being done via his many coils. There is a limit to the high frequency high voltage spark gap abilities. At higher frequencies the gap has to be in microns if the HV goes directly to the gap. This is where I think TK found a way to produce HF/HV but then "recondensed" it with his other coils to enable a spark.
Interesting spark techniques;
http://www.docentes.unal.edu.co/jfvegas/docs/Generator-Zurich.pdf
Also a good read - http://www.hammondmuseumofradio.org/spark.html
HV alternative - http://www.electricstuff.co.uk/marxgen.htm
There is a book out by J.C. Martin entitled "J.C. Martin on pulsed power".
ISBN-10: 0306453029     ISBN-13: 9780306453021
I saw a copy of it selling on eBay for like 500 bucks.
http://www.ebay.com/itm/J-C-Martin-Pulsed-Power-NEW-J-C-Martin-/180743287308?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BUA%252BP%252BFICS%252BUFI%252BIIUM%26otn%3D1%26pmod%3D160659127457%26ps%3D63%26clkid%3D5446731346876795605
Must be a damn good read. I wonder if anyone would have this in pdf format (hic hic).
wattsup
T-1000
Quote from: energia9 on January 07, 2012, 04:07:56 PM
can anyone tell me what this guy is saying?  (uses russian language)
http://www.youtube.com/watch?v=B1PaDvSNLd8&feature=relmfu
http://www.youtube.com/watch?v=tknBz_zhN5c&feature=relmfu
The input coil is running from 220V AC. The core is dual sided, one inside of first coil, then there is 90 degrees ring to primary core where secondary coil is. Then it is connected to step up transformer and bulb.
This simple circuit seems to not consume any power while powering secondary coil.
Question: When you have secondary coil with 90 degrees ring in regards to primary coil core, is load really not affecting primary coil???
