0 Members and 54 Guests are viewing this topic.
conico
energia9
DreamThinkBuild
Hi Energia9,
Neat videos. On the second video link he describes a little bit in the description of how it works but no specs.
Translation:
QuotePOWER-INFINITY
Objective: Preservation of the phase shift in the primary winding through a phase shift in the secondary winding.
Basis: The phase shift is formed where the positive charges are handled by the current magnetic field south pole TP and vice versa, the negative charges - the north pole.
Solution: The secondary winding is made of two identical coils connected in series (the output from the output), sm.shemy Fig.1-2.
Result: Since the electric fields obm.5 obm.4 isolates of the magnetic field TP, EDS in obm.4 does not arise, but at the expense of similar poles of MBP. 3-4, directed towards each other, the magnetic response is absent, the phase shift, as in the MBP. 3-4, and in the entire chain is present. TR runs at idle under load 100 ... 200%.
The cost of kilowatt / hour = $ 00 + free $ from the purchase of gas, oil, nuclear fuel.
stivep
creating hv impulse.
High Voltage Pulse Generators[/font][/size]
http://www.appliedenergetics.com/default.aspx/high-voltage/high-voltage-pulse-generators
High Voltage Arbitrary Waveform Generator
http://www.appliedenergetics.com/downloads/product-offerings/arbitrary-waveform-generator.pdf
We have developed a novel means of charging each stage’s capacitors, C1 through Cn, using “air core magnetic flux.”  The stages are built
inside “rings”, which have secondary coils on the outside diameter.  A
primary coil is outside the rings with adequate spacing for the high voltage insulation between the primary and secondary. The primary coil ’s
magnetic field induces a voltage in the secondary coils. The secondary
coils drive voltage multipliers to charge each stage’s Cn and generate
the gate driver’s power . The stages are arranged so that the voltage
rises linearly along the stack of rings.
instead of capacitors they utilize  concept above
HIGH-VOLTAGE MOSFET SWITCHES
http://www.hvswitch.com/OperationNotesStandard.pdf
MOSFET Switch Block Diagram
http://www.hvswitch.com/HVSwitchBlockStandard.pdf
Fluke 5205A
http://www.buy17.com/FLU/pdf/FLUKE5205A.pdf
I have this one but the problem I have is that 1100V AWG is lost due to low impedance of  flyback or  1:10 transformer.
5046E
http://www.lasermetrics.com/pdf/5046_manual.pdf
I have this oneit does have 0:10KV DC
and rising edge and trailing edge  BNC outputs+ precision potentiometers  to adjust
What I do not have is HV switch that will be slicing 10KV DC to impulses using both BNC listed above .This switch is build into Q head laser optics.I need to create my own and that is not easy unless someone know it better.
It does have trigger BNC from regular generator.
look at the schematic named flyback driver
http://www.manio95.elektroda.eu/zvs-flyback-driver/
very simple example of flyback driver for experiments
http://www.youtube.com/watch?v=8Jotp30aivY
Wesley
PS: addition to the post:
A  Pulse  Sequencer  for  the  KAON  Factory  Beam  Chopper
http://accelconf.web.cern.ch/AccelConf/p93/PDF/PAC1993_1148.PDF
P U L S E   S H A R P E N I N G   B Y   M A G N E T I C   C O M P R E S S I O N *
http://slac.stanford.edu/cgi-wrap/getdoc/slac-pub-5432.pdf
dllabarre
Quote from: ronotte on January 06, 2012, 01:07:16 PM
@wattsup
I did lot of work driving mosfets like irf820, 840, etc simply using a small commercial (low cost) 'pulse transformer' (5KV isolation) with easyoutput  DC level auto-restoration (alternatively it is also easy to wind small ferrite ring with equal effectiveness). I used it extensively for TPU 3 freq generators/switchers. Same approach can be used to drive easily halph bridge or full bridge switchers. It is a quick and safe way. I could send you detailed info.
Roberto
Please send me a copy of the detailed info on this circuit.
Thank you
DonL
