0 Members and 25 Guests are viewing this topic.
Hope
As far as this SUPERCONDUCTOR wire transformer youtube is viable, you will need either SC wire purchased OR the topic DIY Nanotubes should be joined and developed.  The ability of making room temperature nanotubes has been discovered and we can also make a project to build the device to make our own collectively.  Then it can be distributed, Clanzer IMHO would be a great benefit to making this project work.  Nanotubes ARE superconductive  (does this mean they have only one pole?)  or are null neutral?
Verpies, what is your opinion on how room temperature superconductivity works in nanotube technology?  Your educated guess is ok too!
Electron-phonon coupling may be the answer IMHO (or is it photon/electron coupling)
elementSix
I don't Know if anyone has seen this Russian web site but its pretty cool.  I haven't read it all but It has pics and info I haven't seen on other American sites.  Here are the 2 pages, I translated what I could but the writing in the pics is still russky.  I hope those links work.  It's everything from the TPU to Don Smith. 8)
http://translate.google.com/translate?sl=ru&tl=en&u=http%3A%2F%2Fwww.tarielkapanadze.ru%2Fkelly5-1.htm%23kond
http://translate.googleusercontent.com/translate_c?rurl=translate.google.com&sl=ru&tl=en&twu=1&u=http://www.tarielkapanadze.ru/kelly5-2.htm&usg=ALkJrhgpG6H3Sk2MbOS-qLsbiEDf5Xdb5A
ronotte
@wesley,
I've almost completed the 'low power' test of Caduceus/pickup coil device. As previously detailed I'm using about 1.5KV@25-40KHz coming from a low power oscillator. In said situation and using your Basic#2 schematic I'm facing a situation where:
0- I did the overall device tuning by injecting an 1V 40KHz into the system either via an emitting coil (inside Caduceus) or directly trough a capacitor connected at the oscillator output (osc itself OFF). I found max output on pickup coil @ 2.6MHz with ferrite inside (4MHz without ferrite rod): hence far from the input 40KHz oscillator signal.
1- the wave I see positioning the scope's probe after the SparkGap shows max oscillations just after the spark and decreasing amplitude till the next spark: just the contrary of what expected. Is this a way to say that the Caduceus not resonating correctly?
2- the waveform seen on any place along the Caduceus shows neatly that the device cancels all the 40KHz signal coming from the oscillator leaving only the 300-400ns width HV spikes.
3- the SG (and output HV spikes) repetition rate varies from 100-500Hz. The output cap (after the diode) does full charge up to 800V-1000V until the output SG fires generating a thin output spike on load.
In the outlined situation the system clearly does not operate as expected because the energy going into the lamp load is little (0.3usec pulse having about 1KV and 500Hz repetition rate). You certainly already faced that situation and found a solution...
I point out anyway that using the high power oscillator (20-30KV neon sign oscillator) I have found that the circuit behaves much like detailed by the STAAAR group...even if I did not see OU evidence at the time but I have been unable to fine tune it up as all suddenly sparked inside and I have not yet been able to set it up again. Is it correct to say that the device needs an over the threshold power in order to operate correctly?
Thanks, Roberto
ronotte
As requested please find attached  a significative part of the mosfet driver /pulse transformer design. Complete PSPICE simulations and actual operation are available.
Roberto
