0 Members and 264 Guests are viewing this topic.
FreeEnergyInfo
energia9
Quote from: elementSix on January 08, 2012, 01:04:44 AM
here is Tariel's VIDEO with ENGLISH CAPTIONS.  Click on file factory above his pic..
http://translate.googleusercontent.com/translate_c?rurl=translate.google.com&sl=ru&tl=en&twu=1&u=http://www.tarielkapanadze.ru/index.htm&usg=ALkJrhjmpmEZQGCBKcJdsMxX7sWZc9LB2w
thank you very much, finally someone who have posted a translation so others can understand what he says. thank you x100g
i did not understood correctly, did kapanadze use 2 grounds?  1 for transmitting, one for receiving?
and..
can anyone get the document, picture in what is seen at a paper document at 51:57  ,  the left schematic like drawing, seems unseen to me, its hardly visible, i collect these tesla drawings of shcemas but i never seen this one??
I URGE EVERYONE TO FIND THAT IT MAY BECOME VERY HELPFUL....
*edit*  found it left hand drawing is called linde's condenser
http://home.earthlink.net/~drestinblack/generator.htm
wattsup
@stivep
Those are very impressive pieces of equipment. I am always amazed at the amount of equipment you have in your lab.
Maybe next time my wife and I drive down to NY, we could stop for a small visit. We usually hang around Times Square. Last summer we walked on Broadway from TS all the way down to ground zero. We have done that several times now since 911 just to pay our respects.
From the other links you put up it looks like you are thinking about chopping the HV line to produce a higher frequency spark gap.
Funny though, when I Google "High Frequency Spark Gap" there is only a few mostly unrelated links. Seems like a HFSG does not exist. lol
But we are not the only ones that have to live with these realities or are trying to surpass the limitations. Check this pdf from Los Alamos Labs. Maybe some good learning from the pros with the real bucks. lol
http://purco.qc.ca/ftp/Tariel-Kapanadze/Wessley-WNY-Group/flyback-transformer/resonant-converters/
wattsup
Added:
@TEXTRON just mentioned the above file was damaged but now it is fixed. I think you will have to clear your cache as well. In Firefox do Tools-Clear recent history - then just choose the "cache" and how far backwards.
TEKTRON
Quote from: wattsup on January 09, 2012, 01:23:58 AM
wattsup
Wattsup, pdf DL says file is damaged and cannot be recovered
ronotte
@interested in Caduceus-pickup coil device
As I completed the low power test I thought interesting to have a 360 degrees view of the various waveforms as captured on my prototype and so gain  a complete operational view.
In the collage picture I've set in the center the Wesley version #2 schematic and all around the annotated pictures and pointing lines. In each picture the '0' level is in yellow. All the HV waves are captured using a 5KV (DC coupled) probe. Generally the vertical scale is set  to 500V/div and horizontal axe is 0.2msec/div.
COMMENTS
Pic in upper/left corner. This pic shows the LCD PS module output signal that appears to be 1.3KV @30KHz. This signal has not a stable amplitude as the module itself does not support adequately the load...but all in all it seems good for my purposes.
Pic in the upper center location. This pic shows the wave at the SG input and it is possible to see that the SG's fire rate is 2KHz with a big periodical  DC level shifting of about 1KV.
Pic in the upper right position. This pic shows the waveform just after the SG. The signal here is mostly sinusoidal meaning that the Caduceus coil   tank resonates at least partially...but enough to extract the first harmonic. Here I do not see any trumpet-like wave but rather a continuous wave.
PIC center left. This wave is referred to D3 anode and shows that Caduceus cancelled  all the 30KHz sinusoidal signal leaving only a  pulse swinging from -3KV to  800V and bearing same repetition rate.
Pic lower left. In this peak it is easy to see the staircase like of C4 charging. The charging restarts after the second SG fires as expected.
Pic lower right and center right. These two pictures show the pulse on lamp, The 450V pulse has 200nsec width at his center. Clearly the lamp is not lighted.
Roberto
