0 Members and 42 Guests are viewing this topic.
wattsup
@ronotte
Thanks for your post. It is a great work showing those peripherals and your comments are spot on right.
The bulb not lighting is the big question. I saw the same thing with the same diagram.
Showing the loading at C4 is great.
With your system, if we say the output coil at D3 has three leads, top (not used), center (used) and bottom (used), what if you remove the D3 diode and put the top to the bottom and use both sides of the HV AC?
wattsup
Hope
Having seen your great message Ron    TY!    I am trying to make tuning the hammer coil easier by making it moveable upon the main coil (it can be moved forward or backward of the center of the main coil) AND also the connection point to the hammer coil is moveable to enable it to be tuned to exact electrical center due to the lack of a C3 tuning capacitor available.   My budget is dedicated to the building of the cold fusion prototype since you all have linked the original papers and I have a great gases plant designer living close (who is retired).  I am certain I am on a good path because so many positive doors are opening on the projects at hand.  It has taken a long time to decide which devices are most promising and could be built within my constraints.   Wattsup,  thank you for your fine efforts and fortitude in replications.
Wesley,  we thank you and your associates for your humanity and long suffering to promote the free energy cause.  I too feel the yoke device has promise if the magnetization or higher tuning till peak saturation has happened.  Please message me concerning the "special effect that was so monumental".  I have a hint at what it may be and this is not inconceivable.
Hope
Ron,    Your device that sparked (shorted) may have cascaded going beyond your insulation limits.
It sounds hopeful and I would think your on a good path.
ronotte
@ interested on caduceus & pickup coil device replication
Little device's tuning develops the much wanted real Trumpet-like waveform on the pickup coil or anywhere around the device and the much steeper staircase charge on output cap...
Roberto
FreeEnergyInfo
