0 Members and 129 Guests are viewing this topic.
T-1000
Quote from: wattsup on January 14, 2012, 01:39:13 PM
I had just placed a nice coil under the main spark gap (image below) and put my scope probe only on one side of the coil the see how the spark was generating its waveforms. I also post an image of my completed set-up with output made. Damn flyblack I can here some fizzling sound in the HV coil. Probably has an internal short that is bypassing a portion of the wind since now I am getting a very weak spark.
Anyways, I will try to see if there is something else wrong that I have overlooked.
wattsup
Please see and listen spark gap in http://www.youtube.com/watch?v=tWsPwynGP_c
Magnetic quenching of spark gap is very important for sharp pulses and best effect.
Also there is large induction because of capacitor discharge making lots of amps in sparks.
http://www.youtube.com/watch?v=p9llYS_3s5Y
FreeEnergyInfo
FreeEnergyInfo
KAPANADZE  REPLICATION
www.youtube.com/watch?v=9YPsfuYPrd4
DELAMORTO REPLIKACION KAPANADZE  2012.01.14   VIDEO  ....
www.youtube.com/watch?v=qVIoj_eOTxo
SYCRET  ARHYV  DOC. PDF. SHEM .......
www.depositfiles.com/files/2na0gcy8a
COPY  - PASTE BROVZER ADRESS .....
www.narod.ru/disk/37728302001/ARHYV 1.rar.html
www.freeenergylt.narod2.ru/delamorto/
THANKS ANONIMUS ....
FREE ENERGY  ==  FREE INFO !!!!!!!!
Kator01
Quote from: Hope on January 14, 2012, 03:21:15 AM
LOL    I have to laugh about an half hour wasted trying to learn a simple cad program (double cad xt).  I better just draw it and scan it.   I have been out of the loop years and though I knew Velleum well enough, I am not able to make a line not jump into the center of the circle on this cad program.
Yes I will make you all a schematic.   The printer I use is wireless and the friends are sleeping just now (12:15AM PST) so I will draw it out tomorrow and post it.    I thought my words were clear, if you want to use just a 12vdc battery and connect it to 5 magnets and measure the flow then reverse the leads you will see the arc (plasma) jump across, then a no flow condition will be measured.   This is interesting effect and can be worked in to what I described tomorrow.
Use 9 magnets and the flow will be lessened but the spark on no flow will be like a small lighting bolt but bright blue.
PS  After studying the research original documents Andre got his E= Cat CF ideas from.   An educated guess about the secret catalyst is in order.   If Andre used fine iron particals magnetized (like copier toner) within the chamber the magnetic field would be unable to be held within the iron when heated enough and that field would have to go somewhere...   Then the first company he partnered with ,said "they found another way to produce catalyzed effect" so their effect is to use electro magnets pulsed perhaps.
Edited     please use neo magnets if you have them,  I don't know if regular types will work this way.
E-Cat   may be a cleaver elude to electronic catalyzer and the only electronics in his first device was the heating coil (or could be the action of the magnetics being transfered while heated)
Hope,
I miss your schematic of the magnetic diodes so much...  :'(
Kator01
ronotte
@wattsup
sorry for delay... of course you cannot test your HV diodes with any standard Ohmmeter. The HV diodes are made by putting in series from 20(?) to 100 or more diodes so, considering that each diode has at least 0.6V drop it means that in order to check it you have to use for example a voltage > 100VDC. Reassuming: just put a 100K resistor in series to diode and connect it to a 100V DC power supply (any voltage > 100V is good). If the diode is open you will measure (on diode) the same PS voltage, if the diode is good you will have a lower reading.
@all,
I am continuing to try to improve my caduceus & pickup coil device. Now I am able to see on pickup coil output a Trumpet wave about 2000Vpp @1msec repetition rate. THAT IS A GREAT IMPROVEMENT FROM MY START: 200Vpp, hence I'am happy. In the same time, after reading what said by Tesla on coil amplification (he was speaking of a factor 1000-10000), I feel that I'm still far away. The Trumpet wave anyway has a limit of 1KV peak...but is normal as may SG is just 1KV. I've checked that using a 500V arrestor does produce a 500Vp Trumpet, so I will try to go up to 2KV arrestor and see if I'll be able to have a 4KVp wave.
Roberto
